Question about Echo Gas 20 In Blade Double Reciprocating Double Sided Hedge Trimmer SHC225
Maunel starter on my weedeater broke i need a knew one where can i go to get it?
  • 26 Answers
Hi bigmac--
Check your yellow pages for a nearby lawnmower repair shop. They should be able to match an original manufacturer's pull cord to your specific trimmer. If you're adventurous, you can also visit your local home center or hardware store and purchase a generic pull cord. Fitting its length to your machine can sometimes be a challenge, though.
Hope this helps.
Posted on Oct 07, 2010
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
I have a Husqvarna 125L weedeater, New Fuel, has spark but will not start. Pulling the starter rope makes me feel that either I have a compression problem or a clutch problem it is just to easy to pull. I...
Hi there. Firstly remove the end with the starter cord and make sure the fly wheel is opening when you pull the cord. If not lubricate it until it frees.If it is working then it could be just the carb gaskets need replacing or the worst case is that the piston is broke and may need sorting.
Oct 05, 2013 | Husqvarna Forest & Garden 125l 18" Gas...
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
What is the mixture for 50/1 raito for craftsman weedeater? thanks
In truth, I've never found that it's all that important to get it EXACTLY correct.
When I initially purchased my weedeater, I filled the tank, then emptied it into a disposable container of a known amt. What I used was an old plastic container that I knew the size (look on the bottom, it's usually there). If the tank is a half liter (about 2 and something cups), then you're going to want to use about 10ml of oil (about 2 teaspoons of oil.
Here's what I would do if it were mine, take your best guess using what I've said above, and maybe just put a tablespoon (3 teaspoons) in. You'll be fine, and the weedeater won't care either way. Done, easy.
Hope this helps!
Don't forget to give me appropriate feedback, thanks and good luck!
Aug 09, 2010 | Computers & Internet
MY ryobi bc30 expandit starts,but the weedeater head is not rotating
The drive may be broke. It travels from the head to the engine. The drive spindle is attached in a hole at the engine and the engine rotates the spindle to rotate the head. The drive spindle must be broke inside the shaft, the engine or the head. If this is the case, a new weedeater will be a better option.
Jun 04, 2010 | Top Expressions " INDUSTRIAL SPRAY PAINTER...
Weedeater gas TE400. Trigger broke (perhaps
120' cord. I would go to a big-box store and investigate making your own cord so that you only have 2 ends. 12 guage at the very least. any thing smaller, and you will burn up the motor.
I believe that the trigger and throttle cable should solve your issue.
530071550 throttle kit $8.16 + 12.75 shipping
Nov 07, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Pullrope broke on weedeater 550 how do i get it apart to fix it
ther eshoul dbe some bolt holding the pullcord/recoil assenbly to the flywheel/motor. you need to locate and find these bolts first. let me know when you have this apart. you have to unwind the rope and pull it completley out, then buy a new pullcord rope(other rope will just fray and break agai) slip it thru the holes tie a knot wind up the spring and carefu;lly place it back on were it came. let me know if you run into any trouble.
Apr 23, 2009 | Poulan Pe550 Gas Edger
Echo Gas 20 In Blade Double Reciprocating Double Sided Hedge Trimmer SHC225 Logo
98 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
