Question about Lexmark X5470 All-In-One InkJet Printer
My printer is not printing I need to know how to intall the ink
  • 386 Answers
Hi Good day. Here are the ways to install the ink in your printer.
1 Ensure the All-In-One printer is powered on.
2 Lift the scanner unit or access door (
The cartridge holder will move to the center of the Inkjet or All-In-One.
3 Press down on the cartridge carrier latch to raise the carrier lid.
4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge.
5 Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
6 Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge.
7 Close the carrier lids so that they remain closed.
8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed.
9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job.
Posted on Oct 07, 2010
Not printing balank page
first try to restart your pc and printer , if not printing remove print cartrige and shake it and intall it correctly , then try to print following your printer instructions.
it might be there is no ink , or software problem , the above can solve it or even reason is known.
May 13, 2012 | Office Equipment & Supplies
Cannot print even it has a new ink
first :
removed all ink, shut down the printer.
second:
intalls the inks in their respective slots and turn on the printer.
if it failled,
repeat steps 1-2 and reintalls your printer driver.
Feb 15, 2011 | Brother DCP 165C Compact Color Inkjet...
I have intalled all the color cartriges but it kwill not print in color. it keeps saying to install the magenta. I just bought on in wal mart a few weeks ago. I have not been able to print in colr...
The ink cartridges are not properly inserted. Just removed all and return firmly like this demo : http://h20464.www2.hp.com/media/6CBE733F-4185-4C33-80B9-926A56E341F2/html/aio52_ink_replace_cartridges.html?languageDir=en
Or your ink cartridge you purchase in the same quality or not compatible with your printer. please ready your user's manual for ink specification that your printer is not recognizing the ink cartridge.
Nov 21, 2010 | HP Photosmart Premium C309A All-In-One...
Kodak 5500 printer can't detect print head
open the cover and take out the printheads and clean the contact points. also clean the contact points on the printer.
reinstall it and see what it does,also try turning the printer off and on /
if this does not work you need a new printer /the printer hardware is bad for sure if you have already replaced the printhead and catridge .
if printer is in warranty ask for a replacement
Aug 28, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I just intalled a mx310 and I can't figure out how to set it to print in black & white only. I checked "grayscale" in printer preferences but I still get color when printing from the web. Any help would be...
Click my printer icon, then go to printer settings, click maintenance tab and then click "ink cartridge settings". Then select "black only" and click ok and only black cartridge will be used for printing.
Dec 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Kodak Easyshare 5300 All-in-one Inkjet Printer
Hello ocalvin,
You need to clean the printhead of the printer to solve that issue. Because everytime you print, excessive inks are going to the printhead that's the reason why it's clogging the system up. That's because Kodak printers is using "pigments" as inks that's why Kodak printers are producing high quality prints unlike other printers - a photo printed from kodak could actually last for about 100 years. Now back to your issue, you need to clean the printhead from the printer but not manually. You could clean it by going to the software of the printer namely the KODAK HOME CENTER SOFTWARE. You need to click the "?" mark icon on the upper right corner of the software window then under the General Links select Maintenance then choose Clean Printhead. Do it at least twice and then try making prints. If that still doesn't work try calling Kodak Technical Support Representative: 1-800-421-6699
I hope I have been some of help.
Nov 06, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
BLANK paper
Hi ankita, this will update your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Oct 15, 2008 | Epson Stylus Photo R220 InkJet Printer
Cyan ink cartridge is flashing, only prints in blue.
Hi cmwierson, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Oct 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printing/ink cartridge
hi
your printer is not detecting the cartridge, see the pins/connections where the cartridge gets contact, if these are conteminated, clean them. also make sure that you intalled the cartridge after removing its protection seal.
gudluck
Aug 29, 2008 | HP DeskJet 920c InkJet Printer
Cartdrige
go to hp.com search model number then download driver.it 1 hr to download this driver..
Feb 05, 2008 | HP PSC 1410v All-in-One Printer
Lexmark X5470 All-In-One InkJet Printer Logo
343 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
