Question about Fellowes 3011001 Shredder
Motor runs, but will not shred any paper, it won't grab any paper. I pulled out what was jammed, but there are scraps in there still
Sounds like the same problem im having. I opened mine up and the gears that run the teeth are stripped, and im having a real hard time finding new parts.
Posted on Oct 07, 2010
After a paper jam which I cleared as directed, the machine now runs all the time on the ready position and will not stop after paper has been shredded.
At the opening of the shredder there is an extension that is pushed down by the paper that you are inserting. Look for ir. Chances are it is stuck down by a scrap of paper.
Nov 14, 2014 | Office Equipment & Supplies
Jammed paper shredder motor stopped won't start
Had this sort of thing happen to me also; sort of. Did you check to see if the shredded paper level alarm has been triggered in the pull-out catch area? Sometimes it forms a pile that trips the alarm before the catch is full. Sounds simple, but check it out. Also check to make sure it's plugged in! I've done that several times, even to the point of calling for help! Did you know the technical help desk always asks if the machine is plugged in first!
Feb 20, 2013 | Office Equipment & Supplies
Jammed it, removed all paper, now it won't start
Your shredder may be jammed with shreds of paper mashed into the mechanism. Access the mechanism and prepare to remove all ground-in residue bit-by-bit.
Oct 20, 2017 | Office Equipment & Supplies
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
When the paper is fed it is pulled in w/ the bottom right side of the paper going in but not the left side, it becomes uneven and ends up jamming - what would be the reason it would grab and pull the right...
The most likely cause of the problem is an obstruction on the left side of the paper path - most likely a shred of paper from a previous jam. You can estimate where to look by how far the paper goes in before it starts to twist to the side. Sometimes I've had to use a dental pick to snag a shred buried deep inside as an alternative to dismantling the printer. You may find it helpful to use a small mirror to look underneath or behind rollers while you search for the culprit.
Another possibility is one side of a dual pickup roller (two rollers on a single shaft) is worn out. That is unlikely; except for large format units most printers use a single pickup roller.
Jun 06, 2011 | Epson Stylus CX9400 Photo Printer
Shredder will not start when paper is inserted. switch is on auto. This happened after a long session of shredding
Two possible problems;
  1. Teeth underneath lid are jammed; sometimes (especially after a long session) although the papers go through, debris builds up and can get caught in the teeth; to clear unplug and with tweezers or a tina flathead screwdriver, pull out shreds of paper still caught
  2. Motor is overheated; once cool, try it again (move switch to reverse to see if motor is still working). If motor is working, see Step 1 for a jam; some jams can be cleared by running it in reverse. Royal doesn't recommend "long" shredding sessions. My unit recommends sessions of 20 pages or less. If you try to overwork the shredder, it will overheat and in some cases, fry the motor.
I hope this helps answer your problem. Best of luck!
Greg
Nov 12, 2009 | Royal 10X Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
My paper shredder stopped working
First things First...UNPLUG THE UNIT. It sounds like it has been fed too many pages at one time. You may also want to dump any shredded paper so there is plenty of room for the shredder blades to pull in the paper. If the paper catcher is too full the blades can grab shreds from the bottom and stop the blades movement. Just be careful. Shredders can be dangerous.
Jun 01, 2009 | Office Equipment & Supplies
Something is jammed
I was able to unjam an ATIVA DX 180 D shredder now the shredding blades won't turn but the motor is running.
Jan 08, 2008 | Office Equipment & Supplies
Fellowes 3011001 Shredder Logo
439 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
