Question about Saniflo & Saniplus& Macerator Pump
The pump in my unit continues to try to pump.This happens around every 30 seconds
The problem is the non return valve probably at the elbow end of the unit. If it is a new unit then i would say the rubber has not been installed and if it is an old unit the rubber has probably become dislodged
Posted on Oct 18, 2010
    Scholar:
  • Saniflo Expert
  • 115 Answers
Water pressure makes the unit kick on and off. Most likely somehow water is draining back into the pump. It could be from the flapper on the check valve inside the discharge elbow or the flapper on the flush valve inside the toilet tank not sitting properly and allowing water to drain back into the pump creating enough water pressure that makes the unit kick on and off by itself.
Posted on Oct 11, 2010
Panasonic beat pump
Possibly, check error codes for problems:
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display. Note: Display only for "- -". (No transmitting signal, no receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
May 31, 2015 | Panasonic Heating & Cooling
My Panasonic split air conditioner has stopped cooling - model:CU-W18DKR. The internal unit and internal fan operate normally. The external unit fan does not run like normal and no compressor sounds f
Sounds like a faulty outdoor controller board. If you are in Australia, call Prime Electronics or Statewide Appliances for spares.
Part number: NPCWA743383
Or better yet, get a tech to check first.
Feb 10, 2015 | Panasonic Single Split System - Wall...
How do I reset my KitchenAid Model KUDS35FXSS1
The unit normally has a 1:20 to 1:30 fill cycle with pauses in between while the wash motor starts and stops without running a diagnostic mode this normally happens when the control outputs power to the wash pump motor but the pump doesn't start
Sep 13, 2014 | KitchenAid Dishwashers
I have a 1991 Chevy s-10 4.3 fuel injection will crank fine every time runs for around 30 seconds then dies need help troubleshooting
Do you know if the pump continues to run beyond the first 30 seconds ? Are you loosing fuel pressure ?
Jul 23, 2014 | 1991 Chevrolet S-10
I cannot change the SSID or the password, I click on the icon in the setup but nothing happens
I would reset the router, as long as you do not have any complicated parameters set (static routes, port forwards, etc).
Hold the reset button on the back down for 30 seconds, continue to hold down while you unplug the unit, hold for another 30, plug back in and hold for another 30 seconds.
Restart the setup and see if you get anywhere.
Mar 04, 2011 | Belkin Wireless Surf Router (F7D2301)
I have a Trane Heat pump and when temperature gets to around 28degrees F my unit just runs for hours with out cutting off. The temp. I'm trying to maintain is a 69 degree F.
A heat pump starts having trouble somewhere in the low 30' F range. That is why you have or should have auxillary heat. This could be electric heat strips, gas or oil heat, etc. If the auxillary heat is not working then the heat pump will run for a long time if not continuously. I guessing that you are having a hard time trying to maintain 69'F. If you have electric backup then the strips could be burned out. Hope this helps.
Feb 12, 2010 | Heating & Cooling
Dryer turns off after 30 seconds and beeps six times (over and over.....)
other than a good lint cleaning by dissasemble and if not then replace the motor
Jun 23, 2008 | Frigidaire FEQ1442ES Electric Dryer
Display
try checking on the settings maybe you accidenally change the lighting schemes in your unit.
Oct 18, 2007 | Pioneer DEH-P6900UB CD Player
Shuts off after 30 seconds of Play
is the set still under warranty,if so call for service if not when you turn it on try to listen near the side of the unit for a fan noise or high voltage arc sound and do you see light on the screen or in the rear of set.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Saniflo & Saniplus& Macerator Pump  Logo
860 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
