Question about Logitech 984-000006 Pure-Fi Anywhere Compact Speakers Docking Station for iPod (Black)
My Logitech Go Anywhere Speaker system does not charge the battery or operate the speakers. The voltage at the plug from the charger is 12.9 which is OK. On switchon the green led comes on for a second or two then the red led comes on (green out) then no led is illuminated and no function from the unit. Tried the reset but no success. How do I remove the cover to investigate further? David
  • 166 Answers
SOURCE: Laser Mouse MX 1000 By logitech
Pretty much I cannibalized a pack of battery charging adapter plates, soldered the three wires to them, trimmed & bent them a little.. and then epoxied them down to the battery hold-down in their appropriate places. A little trimming was done on the plastic so the contacts could reach in far enough without obstruction.
After having the mouse sit around useless without a working battery in it.. for months, which definitely irritated me... I looked up 3.7V li-ion batteries and came across the "klic-5001 battery" (google it) and ordered two. The first one I destroyed trying to solder the wires directly to the battery contacts.. which just ruined all the internal li-ion battery components(i.e. DO NOT TRY DOING THAT)... the second battery, which I never tampered with whatsoever, is connected to the mouse via the contacts I described above. The klic-5001 batteries by the way do fit very well in the hold-down meant for the original battery.
End result: one, exceptionally well working MX1000 mouse which I can replace the rechargeable battery inside anytime it begins to get to aged and not working so well... ^_^ It charges as normal and the battery monitoring works like nothing ever changed.
Posted on Dec 29, 2007
SOURCE: Logitech mx1000 Not charging.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Posted on Mar 24, 2008
  • 1183 Answers
SOURCE: Logitech Pure-Fi Elite Speaker System
Two things,
1. You get static charged , from your surrounding ,ie the couch or bed you are sitting in or the the chair you are one before you go and disconnect the ipod.
2. The Logitech is not properly grounded. Check for missing rubber pads below. Also check the earthing at the wallsocket where it is connected
Posted on Aug 03, 2008
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
Posted on Feb 18, 2009
  • 527 Answers
SOURCE: Can't find driver for Logitech X-220 speakers
click these links for download
Link 1
Link 2
U can also install related any driver. for ex. realtek audio driver so try to install other drivers also.
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Mar 18, 2009
How change battery?
You will have to open the back of the S315i and you will see a battery pack wiht a cable on it (it looks like three AA cell batteries wrapped up in shrink wrap). Simply unplug the battery connector with no power to the unit, and remove the battery pack.. replace with a new battery and plug back into the slot where the battery was connected. Plug in your speakers for around 2-4 hours to charge the battery fully before you turn it on so that it begins with a fully charged battery. Good to go! It might be a good time to test your charger too so check its output with a volt/ohm meter.
Hope that helps!
Jun 10, 2014 | Logitech Rechargeable Speaker S315i...
My speaker wont turn on ive had it on charge but it still doesn't work?
Most likely you have a blown charger or the battery pack is bad in the speaker. You can try checking the charger if you have access to a test meter, but it might be easier to find another charger with the same specifications and connector, and same connector polarization. I would suggest starting there.
If you can confirm that the charger is putting out voltage, or have a replacement, and it still doesn't work, then consider getting a replacement battery pack.
Testing both the charger and battery pack with a multimeter first, if you can, is the cheapest way to troubleshoot the problem.
Apr 23, 2014 | Audio Technica Car Audio & Video
My bose soundlink mini won't charge or turn on worked fine for a while but now the red battery light is flashing fast every time I try to charge it it's been on the charger overnight and is still doin so...
I love my Bose Soundlink Mini 2. But, I faced a few issues sometimes.
Speaker not turning ONSpeaker not charging with the battery LED blinking.Speaker not getting connected to the bluetooth devices.
But all were fixed by reading through the Manual a bit. To help others, I actually made a video, to show some troubleshooting tips for the Bose Soundlink Mini 2. Checkout the video, if your speaker is not turning ON / not charging / bluetooth not getting connected:
This seems like a very common issue for the soundlink mini 2. This is due to a firmware bug. Gets foxed with a hard reset.Check the video for details and other trouble shooting tips.
Feb 22, 2014 | Cameras
My speakers stopped charging. Now the battery is dead and the speakers are completely useless. Is there anything I can do?
The first thing you could do is trying another charger of the same type, if the battery starts charging you'll only have to get a good charger, if it doesn't, you have a failing charging jack, circuit or battery at portable speakers.
Feb 16, 2011 | Apple Logitech Inc MM50 Portable Speakers...
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Logitech Harmony 890 remote
Not a solution but, you need to be careful when interchanging chargers. Make sure the current and voltage being fed to the device is the same. If you look at the little transformer that plugs into the wall on the original remote charger it will give you that info. It's probably going to be 5 or 12 volts and between 500 and 1000 mA (milliamps).
if the one on your ps3 is the same you're good to go.
Hope this helps
Jan 31, 2009 | Logitech Harmony 890 LCD Remote Control
Logitech mm50 speakers will not charge
Try either eBay, or go to Radio Shack.  You'll find them there.
Jan 15, 2009 | Apple Logitech Inc MM50 Portable Speakers...
Will not charge
If this Problem has come because you not use a speaker for a long time.I Know How to Repair. In This Morning. I had a Problem Like you but I Can Repair it. Try it you Self.I use a Plug and Play a lot of time. lot of charged. and a lot of on-off switch mm50. I do this for a 12 hour. in my school holiday. Battery is become life! . I Can Portable with It Again. but now is mid night
PS.This is true , I test with myself to Resurrection that Death Battery
Oct 03, 2008 | Logitech Inc MM50 Portable Speakers iPod...
SPS1 charging system
Borrow a multimeter and check the voltage (and current if you can) going to the battery while the unit is turned off. It should still be charging the battery if it's still plugged into the wall socket. If it is not getting about 13 volts, it's not going to charge the battery. If that's the case, then there's something wrong with the transformer, or another part of the charging circuit. The downside is you can't use the unit without the battery being connected. If the unit still works and sounds good even though it's not charging the battery, then just put the battery on a separate charger every week or so.(I use the SPS1 for my computer and love it!) Good luck with it. H.
Jul 30, 2007 | Scott SPS1 System
Logitech 984-000006 Pure-Fi Anywhere Compact Speakers Docking Station for iPod (Black) Logo
75 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
