Question about GE WBSR3140DW Top Load Washer
My washer is over flowing. It doesn't stop filling at all sometimes and other times it stops but has already over flowed when it stops. What could cause this?
    Habit-Forming:
  • 84 Answers
You need a presure switch
Posted on Oct 07, 2010
Can low water pressure cause my toilet cisterns to keep running
NO
persistent running is problem valve washers either in the water level control or the flush washer under the press buttons
low pressure will take a longer time to fill but when the level is attained the water will stop flowing in
Nov 16, 2016 | Home
We have a Whirlpool Gas Range, model SF357PEKQ. When I start the bake feature, you can hear the gas flow, the ignitor click (about 4 times) yet there is no ignition of the gas (flame doesn't start)....
Whirlpool had some grounding issues with some of their electronic ignition ranges. Make sure your outlet is grounded first. Then you might need to make sure the bake burner itself is grounded very good against the range frame. I have put star washers between the burner and frame and tightened very tight, that sometimes helps. Also make sure the holes in the burner under the spark electrode are clear from debris. Sometimes the burning of gas leaves a residue that can stop up the holes and not let the gas flow out where the spark is hitting the burner. Hope that helps.
Aug 29, 2011 | Ovens
When my LG is washing sometimes the FE codes comes up, what does this mean? How can I fix this issue?
This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
If water isn't continually running into the washer then the problem can be the water level control.
Jun 23, 2011 | LG WM-2277HW Front Load Washer
Machine fills too slowly and continues to fill in whole cycle
Remove the water filler hoses at the machine and test the flow of each one. If very slow, check the inlet screens on the faucet ends for plugging and make sure the faucets furnish full flow. The hoses themselves can sometimes become restricting of flow--replace them if so. Next, check the inlet solenoids on the machine for proper flow and shutoff when the power to them is stopped. They may or may not be cleanable--replace them if they are trouble. Hope this helps!
Jan 10, 2010 | Admiral AW22 Top Load Washer
Kenmore Elite washer will not stop filling
Dirt in your solenoids may be a problem. But other than that it could be bad solenoids in general. It could also very well be that the unit that senses the water level has a part broken. On the inside there is a tube that connects to the tub. When you add water it increases the pressure in the tube and signals the shutoff. Sometimes the connections on this tube go bad.. or the tube itself gets a hole.
Easy way to tell. Start the unit with the on/off switch. Wait a few seconds then turn it off again. If the water flow doesn't stop you're most likely looking at a solenoid problem. If the water flow stops when you turn the switch off then you're most likely looking at a problem with the water level sensor.
Jul 29, 2009 | Amana ALW880WH Top Load Washer
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
When you turn it on keeps filling water and it over flows , second problem some times when it runs it keeps running to all the cycles never stops tell you manually stop it
Find the tube from the tub to the water level switch. Remove the tube from the switch and blow the sand and stuff out the line. Pump out any water in the washer and restart. 6b0c2cb.jpg
May 16, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
GE WBSR3140DW Top Load Washer Logo
32 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
