Question about Toshiba TP55H60 55" Rear Projection Television
My 55 Toshiba rear projection Will come on, then turn itself off in just about 5-10 seconds. Sometimes I notice the power button is flashing after. What is wrong with it?
    Genius:
  • 1,622 Answers
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck.....
Posted on Oct 07, 2010
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
When watching our Toshiba 50H71 it just turns off then back on.
The power supply will need to be repaired. This is with any tv that turns itself off and then back on.
May 06, 2010 | Toshiba 55H70 55" Rear Projection...
Why does the power light flash on my tv after 15 seconds when i turn it on for sometimes 2 or 3 days.
Hi, this is heat related. you will need to replace the fans in this unit. this will fix this issue. also, inspect the ballast in the lamp area. if it clicks when you are powering up more than 3 times, the high heat may have damaged this circuit that provides the power to the lamp.
May 20, 2009 | Toshiba 55HX70 55" Rear Projection...
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
T.V. will shut itself off, power light flashes
my toshiba tv shuts itself off after about an hour or so
Jan 18, 2009 | Toshiba TN55V71 55" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Red light bflashing
Sometimes a power surge will cause a projection back TV to shut down and flash like that. If you unplug it from the wall and let it sit for a minute and then plug it back in, it should reset itself. If that doesn't work it will probably have to be serviced. If it does work, make sure you get a nice surge protector so you don't fry your TV.
Dec 28, 2007 | Toshiba TP55H95 55" Rear Projection...
Toshiba Cinema Series
possible regulator ic. in the power supply.
Nov 20, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 50" cinema series
Try to unplug and replug back the power cord of the
tv and turn it on again. Sometime this work.
Sep 09, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba TP55H60 55" Rear Projection Television Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
