Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
It take an hour or more per load. My cloths are dry way before the wash is done. Is there something I can do??
    Habit-Forming:
  • 84 Answers
Use the quick cycle
Posted on Oct 07, 2010
Washer capacity of kenmore 4906 4907 ie 5.0 cu feet
The Kenmore 592-4907 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
The Kenmore 592-4906 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
This is the Specs website despite the title :>)
teachmefinance com
Mar 24, 2017 | Kenmore Washing Machines
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    Washer smells like mildew after a load of wash, clothes smell.
    Use a washer cleaner like AhFresh (all three tablets) with the tub clean cycle, no clothes in the washer. Now, only use 1 to a maximum of 2 tablespoons of HE laundry detergent per cycle. Due to low water consumption of these machines, you must adjust soap usage or odors will result. It may also help to leave door open for a hour or so after cycle is finished to allow inner tub to dry completely.
    Jan 12, 2011 | LG WM-2277HW Front Load Washer
    Smells musty and not washing clothes well
    "In washing in the HE washers I think that if you have more than 3 loads a week you should maybe wash your washer at least once a week. I have started wiping the door off and leaving it open between washing and that helps a
    lot with the smell.
    This is why I think if you could wash the washer once a week it would probably do better. You never had this problem in the old washers." Try this in your washer.
    Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Dry soap left on clothes
    machine is not turning clothes over,To mmuch of a load or agitator is not turning
    Jul 12, 2009 | Washing Machines
    Moldy smelling clothes
    First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
    Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
    Jul 01, 2009 | LG WM-0532HW Front Load Washer
    Takes 3 hours to wash a load of clothes
    make sure you are using soap the is for front loading machines. (he)
    Aug 01, 2008 | Frigidaire GLTF1670A Front Load Washer
    Tumble dry is heating but takes forever to dry
    check your air exhaust (including the lint filter) from the air duct connector (remove duct if necessary) on back of dryer to the exterior of the building. Somewhere, there must be air blockage.
    Jun 17, 2007 | Creda IWD12 Front Load Washer / Dryer
    Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
    27 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
