Question about Sony PlayStation Portable (PSP) Console
Error message: The disc could not be read
When turn on psp, the above message appears. I can hear the spindle turns but it won't read the disc and I know the disc is good. Can you tell me what could be wrong?
Chance
Whoeve post this comment is very stupid!! people are asking for a diferent solution ..and u tellin them somehtign they already know //whtathe f u ck !! stupid *** ..
Posted on Nov 05, 2008
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
My wii won't read discs
Made a video showing how I fixed this exact problem on mine.
Jan 16, 2012 | Nintendo Wii Console
Ello. My PSP won't read UMDs. The loading
Most likely the laser is weak. It has been awhile since I have changed a laser in a psp. But first off you should clean the laser with a q-tip and isopropyl alcohol and dry it with the other end of the q-tip. It doesn't take much for them to not be able to read a disc. If it still doesn't work you will need to replace the laser if you aren't that great at working on electronics or very small things you need to find someone to do it for you.
Nov 01, 2017 | Sony PlayStation Portable (PSP) Slim...
Panasonic dvd players error codes
I tried the WD-40 and it worked........thanks a million !!
Mar 28, 2010 | Panasonic DVD RV22K
Psp UMD disc won't work.
try to turn umb auto start off on system settings turn off system put disk in and try again
Jan 06, 2009 | Sony PlayStation Portable (PSP) Slim...
Error code HO2 appears after inserting dvd panosonic NV-VP30EB
To my knowledge, most H02 errors on a Panasonic DVD player would indicate a spindle error, that is the central motor that spins the disc. Normally, this would require an in-shop repair as electronics is involved, however, you could still try:
  • close the tray with no disc inside;
  • press on the back skip, pause, and play buttons simultaneously and hold for about 4 seconds;
  • when the screen blanks and then "initializing" appears, release the buttons.
Alternately, you can try:
  • remove the top cover;
  • clean the spindle motor with compressed air;
  • manually turn the spindle counter clockwise and then clockwise numerous times to exercise the motor;
  • power on the player, insert a disc and manually assist the disc to start turning.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 20, 2008 | Televison & Video
I can not get my PSP to bring up games
open the door to the psp and turn it on. hold down a little black switch on the left side of the disc holder near the spindle. if the laser moves up and down and flashes red than the laser is fine. if the spindle spins ups a couple of times its fine. If both are functioning you need to take a qtip and move the laser all the way to the outside of the track b/c it is stuck and can't read the disc properly. let me know if you need more help. thanks
Aug 05, 2008 | Video Game Consoles & Games
Psp lockout
Based on my experience, this can be due to several things from a bad laser to a bad motherboard or spindle motor, etc... This is not a problem you can fix alone if you're not experienced. When you say "it won't read them" do you also get a disc read error message on the screen, or does the screen stay exactly the same (no message) ? If you answer this I can further pinpoint where the problem is ?
Feb 11, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
74 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
