Question about Sony ECM-44B Lavaliere Microphone Microphone
Through wear and too much handling the wire detached from the microphone. What now?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
UNLESS YOU HAVE EXPERIENCE IN REPAIRING THESE DEVICES, YOU SHOULD TAKE IT TO A MUSIC STORE SERVICE DEPARTMENT THAT SPECIALIZES IN SUCH UNITS. REPAIRING THESE REQUIRES A HIGH LEVEL OF MANUAL DEXTERITY AND SOLDERING OF DELICATE WIRING.
Posted on Oct 07, 2010
2004 Hyundai Santa Fe rear driver side door the outside door handle never worked you can only open it from the inside. accidentally flipped on the child safety lock now I can't open the door at all
It is fairly clear the door handle has detached from the wire that releases the latch. As you cnnot open from the interior handle currently you can only detach the door card and reatach the wire to the door handle. You might have to remove the seat adjacent to the door. I think it is probably a weekend job if you intend doing it yourself. There is no other way it could be done without inflicting damage I think. Essential for safety if you are carrying children/pets in the rear
Good Luck
Jun 01, 2015 | Hyundai Cars & Trucks
How to open a shure beta 58 microphone?
To open a wired Shure Beta 58, unscrew the handle at the mid point. A new cartridge from Shure includes the upper part of the handle.
The Beta 58A is different.
Jun 19, 2014 | Shure SM58 Professional Microphone
My D112 died midsession. Can it be reconditioned? Is it cheaper to fix or replace?
Being a dynamic microphone there is not much that can go wrong with it apart from:
  1. broken / detached wiring
  2. failed diaphragm capsule
before doing anything else check it isn't a cable fault.
AKG products normally have a 2 year warranty so if it's inside that time take t back for repair / replacement.
Otherwise a competent repairer ought to be able to fix it for you cheaper than replacement
Feb 22, 2011 | AKG D112 Professional Microphone
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
3 wires inside are detached. I do not know which is which. Help
See the SM57 User Guide. The User Guide will probably show only two wires. The third wire was used on older mics and connects to the center ground lug of the cartridge.
Dec 13, 2010 | Shure SM57-LC Professional Microphone
Audio technica microphone atm33a socket detached
Unfortunately you will have to contact them here:http://www.audio-technica.com/cms/site/74a0c4b691ac33ae/index.html as they don't seem to have that document listed on their site.
Jan 10, 2010 | Audio Technica Audio-Technica ATM33a...
How to install 95 vw jettta front driver side window regulator
1.remove the door trim paneland the plastic watersheild.
2.this u can skip if u can keep the glass out ur way. but remove the glass.
3.disconnect the electrical connector from the reulator motor.detach the cables from the inside handle.
4.remove the bolts holding the regulator/motor assembly.
5.installation is the reverseof removal.lubricate the rollers and wear points on the regulator with white grease before installation.
6.wear gloves when working inside the door openings to protect from sharp metal edges.
hope that helps if you need more help let me know bertman285@hotmail.com
Oct 06, 2009 | 1995 Volkswagen Jetta
Wiring URGENT
bring it to your local electronics store. they will solder it back togerther for you.
Aug 07, 2009 | Shure SM58 Professional Microphone
Shure SM57 Wire broken off
On the XLR end, you should see a small screw hole. This screw is reverse threaded. In other words to make it go into the mic, you need to turn it counter-clockwise. Once that screw is inside the shaft, the XLR connector should come out. You may need to pull it out using needle-nose pliers. Pull carefully so you don't break the wires.
Dan
Oct 06, 2008 | Shure SM57-LC Professional Microphone
Sony ECM-44B Lavaliere Microphone Microphone Logo
190 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
