Question about Williams 2509612 Ceramic Mid-Size Heater
The pilot light went out..it's hooked up to an electric wall control unit (batteries a fuse good) but cannot light, how do I light it?
  • 59 Answers
Your pilot generator is not detecting the flame from your pilot, causing it to turn off the gas valve. The pilot generator to the furnace can be bought at the Home Depot or HVAC parts house.
Posted on Oct 07, 2010
My Kozy World nat gas wall heater has worked beautifully for the past three winters. I cleaned it this morning with canned air, got all the dust off the ceramic plates, blew out the burner inlets, blew out...
Does the pilot light stay lit if you continually depress the control valve?
If the pilot light stays lit as long as you keep the valve depressed, then the problem is the thermocouple is bad. The pilot light makes enough electricity via the thermocouple to hold open the gas valve that feeds the burners. If the thermocouple fails to produce that electricity, the gas valve will shut down and switch off the gas flow to the whole unit.
Mar 05, 2015 | World Heating & Cooling
Need some troubleshooting tips on a fireplace. I've got the pilot on but when I flip the wall switch nothing happens.
Most of these unit are controlled with a millivolt signal that is generated from the thermopile.
We see this often at the beginning of the year.
Remove the wires from you wall switch and clean them so you have new metal showing and tighten them back to the wall switch.
With your gas valve in the on position try the switch.
If this doe not work do the same thing to the wires on the gas valve where they hook to the TP/TH connecting and the Th connection.
More information can be found at www.allpartsinc.com
Nov 05, 2014 | Leisure HOMEPRIDE Electric Fireplace...
I own a 1993 (but very seldom used) Sharp R-1830 Over-the-Range Microwave. Worked perfectly until a total death yestereve. The oven light went out last week and now the control panel neither lights or...
There's need to remove the oven from the wall to check and replace the fuse.
Just see the video here to show you how to remove the grille and controller assembly.
The fuse is located between the door switches.
If the fuse blows again as soon as you press "Start" to begin cooking, then you likely have a shorted high voltage capacitor.
Let me know if you need further assistance.
You can find helpful exploded views and order parts at the Sears Parts Direct Web site.
Jan 08, 2014 | Sharp Microwave Ovens
Switch on wall fireplace with Honeywell control SV9403, pilot does not turn on even there is current flowing into the controller device.
Good Evening. Your fireplace is equipped with a smart valve (SV) to which the valve itself acts as the control. This unit has intermittent pilot or hot surface ignition. Can you clarify to me which ignition this unit has?
Dec 30, 2013 | Honeywell Programmable Thermostat Heater
I hooked everything up on right the wireing and stuff..the ground cable seems fine i got a red wire hooked to the positive side of the battery. everything seems ok. The amp itself came on a couple of...
Issue With Pre initial Rom Fail To Voltage Routine Check Cause... Static on The Chip Unit Posibility Security Relais Wont click On.. Do do so check for Fuse or red push botton over load security Braker at the back of your unit.. if your fuse is good Well Open the case and surch for more fuse inside of the unit Make shure the unit is unplug from the wall...Then check The voltage on the Transformer to make shure you have the right voltage then check The Regulator The Coil and Capacitor If your not shure Well send it to a Reapair Shop it your best choice Amp cant be dangerous for hazard shock....Good Luck
Sep 23, 2010 | Crown MA-5002VZ 2-Channel Amplifier
No heat
Obviously everything does not work , otherwise you would have heat. You need to tell the story: is this a new installation? Is this the first time this happened and is it only one season old? Have you checked the gas valve to be open ? Is this unit have an electric connection or a pug-in transformer (like a charger unit ) or is there a battery in the ignition control? Or is it a spark starter like you see on barbaque grills and the spark is not ticking? Or does this unit have a pilot light that first must ignite from the contol unit?
Some pilots get clogged and won't light, therefore the sensor that feels the pilot flame will not tell the gas control valve to operate.Good Luck. Macgivor
Oct 11, 2009 | Heating & Cooling
Gas wall heater won't light
You need to bled the line longer and when you get lited hold down for a good minute.When the gas gave out ,there could trash in the line.I would take the line off and blow gas through it undtil you can smell it.
Mar 12, 2009 | Heating & Cooling
Electrical
try replacing the alternator.
Nov 25, 2008 | 2001 Chrysler 300M
Wall furnace model # SFB50146B Thermal Coupler. Does it have 2 wires?
if the pilot light stays lit, but the burners don't kick on, it's a problem with the thermostat or thermostat wiring, or a problem with the valve inside the gas actuator
Oct 24, 2008 | Montgomery Ward (223600UP) Heater
Williams 2509612 Ceramic Mid-Size Heater Logo
265 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
