Question about Samsung Audio Players & Recorders
I need this item for my home surround system ah41-01101a
How do I connect the Home Theatre System so that I can hear surround sound from the TV instead of through the TV speakers?
watch this ......copy the below item and paste it on google ....there it will show you the whole video...it will solv your problem
Nov 20, 2015 | Sony DAV-SR2 System
What cables do i need to connect to a t.v. to get surround sound please
It depends what the source of the sound is. If you are using a dvd player or hifi/dvd combo that has surround, dobly pro logic, surround simulation or cinema sound...it will have HDMI, Optical, Digital outputs. The newer items use the HDMI to send Audio and Visual signals to the Hifi. If not...you will either have to do the simulation on your hifi if it has that feature. You can also use the SPDiF or Optical cable from your source to the hifi. If all that is missing...the standard 3-way RCA cable (Yellow,Red and Black) will do where yellow is video and the red and black is the stereo source of sound.
Apr 24, 2014 | Technics SC-DV290 System
How to connect martin ash system to tv
If you have a surround sound system at home and you have speakers with it you switch your speakers with the Martin ash speakers and hook them up the same way you have your old surround sound speakers but if you do not have a surround sound system already you need a receiver
Apr 30, 2012 | Mitsubishi Audio Players & Recorders
EZW-RT10 (S-Air) surround speakers not working (power/on-line button) flashing. Was working fine for a year, then stopped working.
Do you need a new pairing of surround. select the pairing menu at the home, turn on the surround and press the button that is below the s-air cartridge. A red light will light the rear surround and make a new pairing.
Jun 05, 2010 | Sony DAV-HDX678WF Theater System
Can I add this to the 5.1 home theater surround system?
Hook RCA audio wire/ cable between home theater line out terminals and line in pins of Panasonic shelf system to get sound in its speakers.
Aug 28, 2009 | Panasonic SC-AK78 CD Shelf System
Hook up to tv
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Feb 13, 2009 | GPX DV7500 System
I lost my remot control and the manual
you can purchase this items thru phone calling jvc directly 1-800-252-5722 or on there website jvc.com. the remote will cost $27.01 and the manual $6.18 plus tax and shipping. you can pay with visa or mastercard. if you hear sound thru 2 speakers there's a surround button on remote that can get the rest of speakers working. or you will need to check speaker connection and set unit to right surround setting by pressing surround button.
Nov 17, 2008 | JVC THD-50 System
HOME THEATER SYSTEM SET UP
75 ohm coax cable generally does not carry 5.1 surround, you may need to see if your cable box has a 5.1 surround capability, the cable company will be able to help you on that .one other thing the receiver you are using (distribution) may need to have the source changed to the one from the cable box ie. fiber optic or coaxial (orange rca plug). red and white from the cable box does not carry 5.1 surround, only stereo. thanks for using fixya!
May 27, 2008 | Samsung Audio Players & Recorders
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
270 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
