Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Video was stretched inward - Sony FD Trinitron WEGA KV-24FS120 24" TV
I need a new brush where can I buy it
Ebay Various sizes in a selection for $4.95
http://www.ebay.com/itm/10-Pcs-Power-Tool-Replacement-1-4-x-1-4-x-9-16-Motor-Carbon-Brushes-/310696047268?pt=LH_DefaultDomain_0&hash=item4856ed72a4
You might not even need a brush. Locate the spring which pushes the brush inward and stretch it a bit, this will re-seat the brush. Also, spray the brush assembly and armature contacts with silicone spray.
Oct 16, 2013 | Saws
4wd
That bolt keeps the axle from moving inward into the hub, may not matter during normal driving but during off road driving when the suspension is stretched it may cause the splines to strip on the axle/
Jun 26, 2013 | 1996 Toyota T100
CAn someone show me how change the fan belt on hyundai amicasi
undo the bolts on the alternator and swing it inwards towards the block,change the belt then swing the alt back out using a lever to torque up the belt so that the longest stretch has 1/2"of play,then tighten up the bolts,thats it job done,(after running the engine for about 100 miles check the tension again).
Feb 25, 2011 | 1997 Hyundai Accent
How to replace a fan belt
on a staight four cylinder,you just undo ALL the bolts on the alternator and swing it inwards towards the block.replace the belt and use the alternator to tighten the tension of the belt so that the longest stretch has 1/2"play.use a long screwdriver as a lever.
Jan 11, 2011 | Peugeot 504 Cars & Trucks
How do i change the fan belt on an m reg 1.6 si ford fiesta. please give a diagram if possible.
havnt got a picture but just loosen the three bolts on the alternator,swing it inwards towards the engine block and remove/fit new belt,swing the alternator back out and tension the belt before doing up the bolts,use a long screwdiver as a "crowbar"to tighten.The belt should have 1/2/"play on the longest stretch between pulleys.....check the tension after 250 miles.(yes,it is that simple).
Dec 31, 2010 | Ford Fiesta Cars & Trucks
How do you replace the alternator belt on a 2003 Kia Rio? The belt just broke and the only idiot light that's lit is the battery light, so it probaly isn't the serpentine belt.
undo the alternator bolts and swing it inwards towards the block,replace the belt and lever the alt away from the block to tension it (1/2"play on longest stretch between pulleys) use ring spanners.(wrenches)
Sep 15, 2010 | 2003 Kia Rio
To fit drive belt
release bolts on alternator and swing it inwards then replace belt and pull alt outwards to tighten,longest stretch of belt should flex no more than 1/2"after all bolts are tight.
Sep 02, 2010 | 1994 Volkswagen Golf
Inward calls are garbled and there is no video inwards
i am sorry but i have no idea. even i have a problem that is why i am here
please ask someone else
thank you
david
Jul 16, 2009 | Computers & Internet
Symphonic sc1304, vcr problem
Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
Jun 04, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Video Card Problems
Sounds like the video card is heating up too quickly and can't get rid of the heat fast enough. Maybe you need to check the fan on the video card or get another fan to circulate the air more within your PC. I currently have 3 fans blowing inward in my PC and 1 blowing outward. 1 mounted on the front, blowing inward 1 mounted on the side, blowing inward 1 mounted on the top, blowing inward 1 mounted on the back, blowing outward I used to have problems with my video card acting up from time to time and this seemed to help keep not only my video card cool, but also my CPU.
Apr 05, 2007 | ASUS A8N-SLI Premium Motherboard
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
