Question about Vizio L32 32 in. LCD HDTV
The screen is white. You can hear sound. You can change the channel and hear sound from that also. But the screen stays white. It's a 27 inch HDTV - Vizio, less than 2 yrs old.
  • 11,361 Answers
You get white glowing screen can be caused bt dead T-CON board or T-con board is not getting the 12VDC or 5vdc from the main board to power it.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 07, 2010
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Tv turns off right after i turn it on
I have not repaired one of these in a lonng time. But lets take a stab at it. I would guess You have bad solder connections on the vertical IC. Resolder this and replace the cap near the IC. Now the reason for the shut down is cured. The white screen will appear and you will have audio and be able to hear the channels change, You need to replace the eeprom. Hope this will help you! I don't have location #s, so this is just off the top of my mind.
Sep 15, 2009 | Televison & Video
Tv stays black
Do you have audio and if so can you change channels to hear other programs? If so ...you have a bad vertical IC. Have a tech turn up the screen control to see a white horizontal line. By your question I would say this will correct the problem.
Jul 26, 2009 | Sanyo DS27510 27" TV
White horizontal lines in my 27 in Phillips Magnnavox tv
I have seen this on mine. Check the cable going into your TV and make sure it is good. The ground portion of the cable could not be making a good connection.
Jan 17, 2009 | Philips Magnavox 27MS343S 27" TV
It's the 26 inch version but have problem with picture
Hi Paul,
It looks like your TV might have a main board failure if the screen stays white without video. Since your TV is less then a year, I would suggest to contact the manufacturers to get fix under warranty. Most electronics devices carry one year warranty.
Good Luck.
Dec 19, 2008 | Olevia LT32HVE 32 in. LCD Television
Magnavox with a white screen, sound, volume and channels working
dont put in back the vertical prossesor ic get a new one and solder it in see what it does.good luck.
Aug 19, 2008 | Philips Magnavox 27MS343S 27" TV
27" GE TV with loud Popping sound
Could be a possible flyback. yes.. for a 27inch i would not think it would be worth it... 27 inch tvs are realativly cheap.. the lowest price to repair would be about 200 if you got lucky.
Dec 18, 2007 | GE 27GT271 TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Channels change without changing channels!
check the tv system control the ic is probably bad have a tech check tv and make the repairs good luck.
Dec 21, 2006 | Sanyo AVM-2759S 27" TV
No picture when I turn the tv on only sound
TRY CALLING BEST BUY'S GEEK SQUAD TO COME FOR A IN-HOME REPAIR SERVICE CALL AND THEY WILL FIX YOUR PROBLEM!
Dec 14, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Vizio L32 32 in. LCD HDTV Logo
278 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
