Question about Texas Instruments TI-30XA Calculator
How do you open a TI-30Xa in order to replace the battery?
  • 75 Answers
To replace the batteries:
• Remove slide cover. Place calculator face down.
• Using a small Phillips screwdriver, remove screws from back case.
• Remove back case.
• Remove discharged batteries.
• Install new batteries positive side up, as shown on diagram inside case.
• Run a coin across the reset pad on the upper right hand corner of the printed circuit board.
• Replace back case, and then replace screws.
• Press [OFF], [ON/C], [ON/C].
Note: The calculator cannot hold data in memory when batteries are removed or become discharged.
Posted on Oct 07, 2010
  • candice_vans Feb 27, 2011
    After you remove the screws with a Philips screwdriver, you need a regular screwdriver to pry the back open. Along the top edge of a TI-30XA there are two notches. Pry these open with a regular screwdriver. It takes quite a bit of force. Pry each notch a little and then pry harder.
  • 7993 Answers
SOURCE: how to open ti-30xa to get to battery beacause the
Here are the instructions. Hope it helps.
Posted on Oct 18, 2009
  • 566 Answers
SOURCE: Need to replace battery on TI-30XA. What is No.
Replacement Battery—DURPX76A675PK
(This is equivalent to Duracell 76A button cell battery and many others: 1128MP, 1166A, AG13, D76A, G13A, GPA7, GPA76, LR44, LR1154, L1154, PX675A, PX76A, RPX675, S76, V13GA, 357A, RW82, KA, A76, 208-904, SB-F9, G13-A, CA18, CA19, LR44, A-76, 76A)
Battery Replacement (TI.30Xa)
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws from back case.
3. Remove back case.
4. Remove discharged batteries.
[Caution: Avoid contact with other calculator components while changing batteries.]
5. Install new batteries positive side up, as shown on diagram inside case.
6. Replace back case, and then replace screws.
7. Press [OFF] [ON/C] [ON/C]
[Caution: Dispose of old batteries properly. Do not incinerate batteries or leave where a child can find them.
Your calculator cannot hold data in memory when batteries are removed or become discharged.]
Posted on Aug 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: What size replacement battery
The battery is an EPX76
Posted on Nov 17, 2009
  • 102366 Answers
SOURCE: How do i replace my texas instrument TI-30xa
Use a small Phillips screwdriver to remove the back of the case.
Posted on Feb 05, 2010
  • 7993 Answers
SOURCE: reset calculator ti-30xa after replacing the
Posted on Feb 20, 2010
What kind of batteries and where can I find batteries for my TI-30A?
I hope you mean the TI-30XA, since TI never released a TI-30A.
The TI-30XA uses two A76 batteries, also known as 357. You should be able to find them at just about any department, electronics, or office-supply store.
Here's the full scoop on changing batteries:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=71660
Oct 21, 2010 | Texas Instruments TI-30XA Calculator
I have a TI -30XA calculator. Need a battery for it. What is the number of the battery? Thanks, Ed
The TI-30Xa uses two A-76 lithium batteries. Comparable battery model numbers include: Duracell® D357 and Eveready® 357
Sep 23, 2010 | Texas Instruments TI-30XA Calculator
REPLACE BATTERY 30XA
The battery is EPX76 (it uses 2)
This page describes how to get into the calculator to replace them;
http://tutorialninjas.net/2007/05/04/replacing-the-battery-in-your-ti-30xa-calculator/
The batteries can cost as much as $5 each, a new calculator can be as low as $10
Good Luck!
Aug 30, 2009 | Texas Instruments TI-30XA Calculator
It's cheaper to buy the new one. On amazon they are pretty cheap. take a look Amazon com TI 30X. cheers
Aug 24, 2009 | Texas Instruments TI-30XA Calculator
My texas instruments ti-30Xa doesn't turn on!
It is battery powered. You simply need to replace the battery. This website may help you.
http://www.calculatorsource.com/ti-30xa.html
Aug 03, 2009 | Texas Instruments TI-30XA Calculator
Replacing battery onTI-30xa
I have the battery powered TI-30xa and I didnt press anything when I was done.
I:
1) opened the back by taking out the screws
2) took out the old batteries
3) put in the new batteries
4) closed the case and put the screws back in
5) it has worked great since.
Mar 25, 2009 | Texas Instruments TI-30XA Calculator
Battery installation for TI-30Xa
Good Luck!
Nov 11, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
561 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
