Question about Ovens
I have an old electric Chef Glendale 600 fan forced stove & oven in my kitchen and the oven has stopped working. (no power to the switch, light or fan) but the 4 plates on the stove top are still working. Does the oven have its own fuse somewhere or if the oven element goes will that cut the power to the oven switch, light or fan? Any help would be appreciated Kim Neil
  • tantarra_com Oct 07, 2010
    Hi, Thanks for your feedback.
    I flipped the cover above the switches. found all the switch's and wiring but can see no fuses. as this is an old stove/oven, (maybe 20 years) would the fuse be elsewhere? or is there a chance that it is the oven element that may have failed.
    Kind Regards
    Kim
    Thank You
    Your advice was wonderful and the oven is now working again. i very much appreciate your time and experience.
    Kindest Regards
    Kim.
    Guru:
  • 642 Answers
Above the switches is a cover which flips up to expose the fuses. Check that the fuses are intact. If you have a voltmeter you can measure for voltage in the centre connecting pin inside the fuse holder.(remove the fuse first). If there is no power the fault would be with the wiring between the terminal block and the fuse. You will need to open the rear panel of the stove.
Since the light and fan are also inoperative I suspect that you may have a wiring fault on the neutral side of the element which also connects to the fan and heater.
Shut the power to the stove off at the wall isolator switch. Remove the rear cover. Check the wiring between the terminal block and fuse. Inspect the connector lugs to see that they fit tightly on the connecting tabs. If not, disconnect the lug, use a pair of pliers and pinch the lug to ensure a tight fit.
Follow the wiring from the element to the neutral connector and back to the junction block for neutral connections. See the simplified diagram below.
  1. Live junction block
  2. Neutral junction block
  3. Oven fuse
  4. Switch
  5. Element
  6. Neutral connector
Posted on Oct 07, 2010
  • Rene Rossouw
    Rene Rossouw Oct 07, 2010
    It is possible that the stove has no fuses(unlikely but possible). If there are none under the cover at the top check the rear of the riser where the switches are located. Also see if there is not another cover below the switches.
    The only way to check if the element has failed is by using an Ohmmeter/multimeter. Measure resistance across the connecting points on the element with the power to the stove OFF. If a visual inspection of the wiring does not show up any problems you can remove the element and switch and have them tested at the supply store. Better yet if you can obtain a multimeter measure resistance across the element as described. If there is no reading, turn the power to the stove on and measure voltage at the element with the oven switched on. If no voltage is found the switch may have failed.
    The switch is removed by pulling off the selector knob. This will expose a nut which holds the switch in place. Remove this nut and the switch can be removed from the rear. Before disconnecting any wiring take a couple photos or make a detailed note of which wire goes where. Tag the wires with masking tape, you dont want to get it wrong.
  • 11,896 Answers
There is a fuse in the back if you remove the rear panel. Check to see if the fuse looks good. If the element is bad, it won't effect the switch, light, or fan. The switch, light, and fan all run off of there own circuit. If that circuits is bad, has a burnt out fusible link, or the electrical circuit board they connect to is bad, then they won't work. You will likely need to trace the wiring from the control panel to the circuit that runs these three things. Use a volmeter to test for power and you can also use an ohmmeter to test for continuity of the circuit itself.
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
Oven locked with door open how do I reset it?
my first thought is if the oven is standard 220 three or four prong electric, for safety, go to breaker switch panel,"in House or outside of house", open pannel door and find the breaker switch marked for "oven" or "kitchen utility" . it will be a double switch of 20 to 25 amp ,"each". or it will b One breaker switch of 45-50 amp. ,switch it to off. then see that the oven has no power, the stove top as well as the lights and the oven .try to unlock it now. by lever or button ? then if not unlocking turn the breaker back on and try it again. hope it works for you.
Mar 29, 2015 | Ovens
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
Replacing element in an old Chef Auto 600 Oven
Good news!
You probably can do this yourself.
Most appliance parts stores will "demand" you give them a model number, but if you find an appliance store that has a smarter older employee, he or she can probably give you the right one by seeing the old one.
Also know the element may be fine.
Older appliances sometimes have bad wires from old age.
When you take this apart, look carefully at the wires that are connected to the socket that the element plugs in to.
You may find the only thing wrong is a bad wire.
Know also that wire connectors for high heat things like stoves are sometimes made stainless steel, for the high heat.
God bless your efforts.
May 12, 2017 | Ovens
Oven fan not working
If you select the function on the selector switch which turns both the fan forced fan and the oven element on at the same time and the fan does not work, but the oven element does then the fan forced fan is faulty and requires replqcement.
Feb 25, 2011 | Stoves 720EF Electric Double Oven
1937 anitque American Stove came with Magic chef cook book and Loraine thermostatic temperature regulator. Having problems getting Oven pilot light to light. Have checked thoroughly for leaks but have...
THE PILOT LIGHT IS IGNIGHTED BY AN ELECTRICAL WIRE THAT IS LOCATED BESIDE THE GAS JETS SO MAKE SURE THE ELECTRICAL IGNITION SYSTEM HAS POWER YOU NEED TO LOCATE THE WIRE AND FOLLOW IT TO FIND THE POWER SORCE THEN CONECT THE POWER SUPLY TO IT , GOOD COOKING.
Nov 22, 2009 | Ovens
Ovens Logo
662 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
