Question about LG LD40E Dehumidifier
This unit continues to run but no water is found in the bucket
  • LG Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Oct 07, 2010
Dehumidifier is still pulling water, but it's not going into the bucket...it's somehow going into the back of the unit, like where the motor is.
The problem lies with the water tubing the drains water into the bucket being clogged. To solve the problem do the following:
First turn the unit OFF & unplug it.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helped you to solve the problem & thanks for choosing FixYa.
Sep 14, 2011 | LG Dehumidifiers
Basement smells musty, fan won't stay on continuous
Barbara, are you running the unit in a continuous mode (i.e Using a hose to drain the unit)? Or is the water draining into the water collection bucket?
If you are not using a hose for continual drainage, the fan will not run constantly. It requires that, for continual operation.
Also, you may have the humidity extraction level set to high. Lower it to 35%. Also, remove and check the air intake filter, as it may need cleaning.
Dehumidifiers that are not Low Temp models have a difficult time operating in basement applications. Because the air temp at floor level is colder than at shoulder level. At temperatures between 40 & 60 degree F, regular dehumidifiers struggle to keep up. Raising it up off the flow on to a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water can really help.
I hope this was of assistance and thanks for choosing FixYa.
Jul 29, 2011 | LG LHD459EL Dehumidifier
Hi, I have a Haier HD306 Dehumidifier. I'm having an issue of the water dripping onto the floor. There is no crack or leak coming from the bucket itself. The leak seems to be coming from the back...
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
Jul 26, 2011 | Haier HD306 Dehumidifier
Water on floor after dehumidifier runs for about one half hour either directly drained to sump pump hole or bucket.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers, though.
Hope this helped you to troubleshoot & solve the problem.
Jul 11, 2011 | Dehumidifiers
Dehumidier works fine! However it leaks water even when the bucket is empty and started. Some water collects in bucket but most runs out on the floor. What is wrong?
The drain hole of drain tube, that transports water to the bucket is clogged.
To solve this problem, do the following:
I hope this helps you solve the problem.
Jul 09, 2011 | Haier HD656E Dehumidifier
I have the 25 pint unit and it leaks underneath the bucket. Water does get pulled into the bucket but when running water leaks out at the bottom and puddles on the floor. The bucket has been checked for...
If the unit is leaking under the bucket and you haven't been able to find a crack or hole in the bucket. The bucket may not be properly inserted in to the dehumidifier. Remove the bucket, empty it and reinsert it into the unit making sure that it fits in squarely (Top to Bottom).
If the above doesn't correct the problem, the drain tube to the bucket may be partially clogged. To check this, you will need an 18" long, plastic Zip Tie or something similar. But NO wire coat hangers. Turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the bucket and you will see a drain hole or tube at the top of bucket cavity. Carefully insert the Zip Tie and continue to push it in unitl you reach the bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, slowly remove the Zip Tie while rotating (twisting) it. As you reach the end of the Zip Tie be prepared for some water to follow.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool 25-Pint Dehumidifier
Runs continuously
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers that run but do not extract water from the air..
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 28, 2010 | Frigidaire FDL60P1 Dehumidifier
Unit collects water but periodically continues running despite full bucket which is flush in unit, what could be causing this it doesn't happen everytime.
there is a floater switch on the machine over the bucket (and sometimes in it). the floater tells the machine that the bucket is full. if the floater is stuck, the machine will assume that the bucket is not yet full, and will continue to run. check that floater switch with the bucket out. you may need to press in the bucket switch so the machine thinks the bucket is in. then lift the floater and see if it stops running. if not, the switch is bad.
Jul 29, 2009 | LG LHD45EL Dehumidifier
Water bucket - proper seating
Try re-seating the bucket. I have found some LG models that if not seated all of the way will sometimes keep running and think the bucket is not full even when it is. On the models that I have seen do it the problem is usually the left side of the bucket not engaging all of the way. When you reseat the bucket, feel where the bucket meets the dehumidifier on each side and make sure they are even. If one feels like it is sticking out further than the other and you cannot push it in any more pull the bucket out and try and reseat it again until both sides are flush with the dehumidifier. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 10, 2008 | LG DH404E Dehumidifier
Bucket overfills to the point of spillage
The float is the main feature that keeps it from overflowing. I have no idea why there would even have to be an adjustable component in the circuit. The float is connected to an On-OFF microswitch and may be tested with the unit set to run.
Remove the bucket and manually push upward on the float. If the unit stops running then the bucket may be misalgned,(Make sure float is on the inside of the bucket and not lodged behind the bucket).
May 26, 2008 | Dehumidifiers
LG LD40E Dehumidifier Logo
121 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
