Question about Nintendo DS Lite Console
Cant see any visuals ??
Hi, This unit is only new - April 08 .  The problem is that there is no visuals on the screen, the screen is white / clear???  Nothing displays.
The Nin DS Lite powers on,  the game plays & can hear the game just nothing displays on the screen ??
Any suggestions would be great
Thanks
Kill uself
Posted on May 31, 2008
    Novelist:
  • Nintendo Expert
  • 127 Answers
Less than a year from buying date, then you must have a warranty from Nintendo so try contact their customer service and they should repair it for free.
Anyway if only the top screen then that problem might be a loosen top screen ribbon cable but you have to dismantle the unit to put it right in the connector and you gonna need tools and some video guides you can find in youtube.
If not enough confident about and dont have a warranty then take it to a repair shop.
Regards...
Posted on May 29, 2008
How to reset Toshiba Studio 256se Total Counter?
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Jun 14, 2016 | Toshiba Office Equipment & Supplies
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
Visual Land Prestige Elite 10Q+. Why is it stuck on displaying the logo?
Search Results
    Visual Land Prestige Pro 7D Repair - iFixit
    https://www.ifixit.com/Device/Visual_Land_Prestige_Pro_7D
    iFixitThe Prestige Pro 7D was replaced in April 2014 by the Visual Land Prestige Elite 7Q. The Elite 7Q runs Android 4.4 KitKat, and has a Quad Core Processor ...
    Visual Land Factory Reset on Prestige 7L - YouTube
    ? 2:39
    https://www.youtube.com/watch?v=QoiLEpT3E4o
    Oct 8, 2013 - Uploaded by VisualLandInc
    How to do a factory reset (hard reset) on a Visual Land Prestige7L. ... mine is stuck on jelly bean screen i ...
    Visual Land Re-Flashing tutorial - YouTube
    ? 4:15
    https://www.youtube.com/watch?v=YC0bbGyXwBk
    Jun 16, 2012 - Uploaded by Macktion
    My visual land prestige elite 8Q quad core entertainment android tablet ... is stuck on the loading screen i ...
Dec 16, 2015 | Tablets & eReaders
OS
usually OS or O/S stands for 'Operating System'
This some software - a collection of programs - that enable you operate your computer. For example they tell the computer how to interpret the use of keyboard and mouse, and how to send images to the screen or visual display unit (VDU). Read in more detail here http://en.wikipedia.org/wiki/Operating_system
21.April.2014
Apr 21, 2014 | Acer TravelMate 5720-6635 Notebook
Toshiba estudio 282 code F100
After replace new hdd, u need to performs following:
Update of HDD program data and UI data.
1) Create partitions. (In case of using the download jig, this is not necessary.)
While pressing [3] and [CLEAR] button, turn the power ON.
When "Firmware Version Up Mode" appears on the LCD, key in [3] and press the [START]
button.
2) Format the HDD. (Setting Mode (08-690: 2))
3) Update with the download jig or USB storage.
4) Format the HDD. (Setting Mode (08-690: 2))
* When the FAX unit (GD-1150) is installed.
Start up with the FAX Clearing Mode (1*)
Perform the 1*-100 (FAX Set Up), 1*-102 (Clearing the image data) of the FAX Clearing Mode.
Feb 25, 2013 | Toshiba e-STUDIO 282 Black and White...
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
Paper Jam Cannon Image class MF6550
its the registration sensor flag... change it.
Jan 13, 2009 | Canon imageCLASS MF6550 Monochrome Laser...
Starview codes
http://www.starviewcodes.zoomshare.com/
Check out that link. Seems like the latest updates are from late April 2008.
Chris
Jun 04, 2008 | Toshiba Sattelite A105-S2071 Notebook
INTERNALLY VISUALLY BROKEN ! : [
You screen is gone ( burned ) <due to high impact falling down, too much of use heats up the screen>
don't cost much but it's a bit difficult to find.....try amazon.com
PLEASE RATE ME AS ( FIXYA ) <blue boxes>............
May 27, 2008 | iRiver X20 MP3 Player
Nintendo DS Lite Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
