Question about Hotpoint RGB745 Gas Kitchen Range
I have a problem with my Hotpoint Range; the range top works, the broiler works, but the oven does not! The oven igniter seems to take a couple of minutes to ignite the gas. It comes out quickly but then turns down to a very low rate. What needs to be replaced?
  • Hotpoint Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Oct 07, 2010
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
Gas oven, broiler and stove top work, but bake does not
heatman101
Nov 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
My stove top and broiler work but my oven won't ignite. Could it be the glow bar?
It's a good possibility. The broiler and oven use separate igniters. So, if the broiler works, you don't have a gas problem. The surface igniters use an electrode via a spark module, so its a completely different ignition source.
No ignition in the oven is most commonly attributed to an oven igniter that is going bad. As these igniters age, they become weak and require replacement. The following link explains some theory behind how they work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
Replacements parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary, so shop and compare.
NOTE: If the replacement igniter comes with a connector plug that does not match the one on your range, you will be instructed to cut the old connector plug off and splice the wires together using a set of ceramic wire lugs that are included in the replacement kit. DO NOT attempt to use standard wires lugs. They will melt due to the extreme heat in an oven. The ceramic lugs and the wires on the igniter are heat resistant.
If you have any questions about this repair, please let me know. I hope this helps you.
Dec 24, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven will not light but broiler works
More than likely the igniter for the bake manifold has become weak over time and now needs to be replaced. Each burner manifold in the oven has a separate igniter. That's why your broiler still works. Due to the frequency of use, the bake igniter wears out faster and may require replacement more often. The following link explains a little theory on how these igniters work and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have any questions, please let me know. I hope this helps you.
Jul 09, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint oven and broiler won't turn on
Since both broil and bake do not work you must replace the ERC (clock).Part number WB12K0020 about $150.00.
Apr 01, 2009 | Hotpoint RGB745 Gas Kitchen Range
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint Gas oven doesn't light
Is the gas valve easy to replace on a gas oven?
Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
OVen doesn't Heat
More than likely, you have a bad igniter for the bake manifold. Since the gas range has a separate ignitor for the broiler, this explains why the broiler works and the bake function does not. Since most consumers tend to bake more often than broil, the bake ignitors go bad more frequently. There are a couple of different ignitor types listed for your range. I will need an EXACT model number (located somewhere around the oven door opening) before I would be able to give you a correct part number. The ignitor price varies between $52 - $64. If you wish to make the repairs yourself, I can give step by step instructions. Please post back with your information and I will be able to assist you further.
Jan 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
Broiler won't light
gas=replace igniter(top)
electric=replace top black heating element!
Oct 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
171 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
