Question about Beverage-Air MT19 Refrigerator Commercial
Hi i'm trying to purchase a new compressor/motor for my Beverage Air MT19 cooler but I having difficulty locating the correct part number.
    President:
  • 1,891 Answers
Most comperssors have on them the brand / size / and numbers ot them and the mfg use differnt brands in ther models. if your have a ref supply house in your area see if they can cross it to a brand that will replace it . hopt this helps mm
Posted on Oct 07, 2010
What does the overload relay look like a Beverage-Air MT27 Beverage Cooler Commercial
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
Sep 27, 2011 | Beverage-Air MT27 Beverage Cooler...
Hi My Kelvinator Beverage Cooler fridge has packed up due to power surge. If possible please could you email me a quotation as i need to purchase another one. Description: 1 door which is glass and its...
Hi.
The price depends on the model and on the internal volume. Here a UK seller: Commercial Beverage Coolers & Commercial Bottle Coolers. Here a SA distributor of beverage coolers. The choice includes Kelvinator.
About the fault. If the problem happened after a power surge it is often possible to repair the cooler replacing the starter relay mounted on top of the compressor. The part is not expensive. Call the Kelvinator number listed on the owner manual to know more about the possible repair or to purchase the part.
Regards.
Ginko
Sep 13, 2011 | Kelvinator Refrigerators
Water is leaking from my Beverage-Air MT27 ?? Had moved it from one location to another. Delivery man laid it down and told me not to plug in for 24 hours. Was fine for 2 days now it is leaking water.
The condensate is supposed to drain from the evaporator down to a pan underneath by the compressor. Is is possible that the tube is not aligned with the pan any more. It is simple to check, remove the compressor compartment cover and inspect the pan and the tube. If the tube is out of place, just reposition it. This is likely the problem you are having. Also make sure the pan is correctly positioned.
May 22, 2011 | Beverage-Air MT27 Beverage Cooler...
I have a Beverage Air model MT 27. Coils have been cleaned and recharged with freon. Cooler will not cool below 50 degrees?
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Jan 28, 2011 | Beverage-Air MT27 Beverage Cooler...
My fridge was cold in the morning then warm by afternoon
from your description, it sounds like the start component for the compressor was replaced with a generic 3 in 1 kit. No uncommon and the kits are pretty reliable. It could be that one of the wires from that kit came loose from the compressor. Make sure all 3 terminals on the compressor have wires connected and the fan next to it has 2 wires hooked up.
check it out.
May 12, 2010 | Beverage-Air MT19 Refrigerator Commercial
Have commercial beverage air kegerator that keeps tripping fuses when plugged in, what's wrong
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Oct 25, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
No longer cools.
This refrigeration system may be under extended warranty.
Otherwise check the compressor start relay for loose or burned contacts.
Mar 08, 2009 | Avanti WC494D Compact Wine Cooler Beverage...
Beverage-Air MT19 Refrigerator Commercial Logo
73 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
