TV will not power up
I have a Mitsubishi WD-62825. I turned it off a few days ago and the next morning tried turning it back on. The TV will just not power up. I think it may be a blown fuse but where would the fuse be located and is it hard to replace. I have had the back off before to assist in replacing the lamp but don't remember seeing a fuse.
  • Rickwo May 30, 2008
    No lights at all come on. I have dealt with the flashing green light in the past. I have been able to unplug the tv and plug it back in, hit the reset button a few times and it eventually stops blinking and powers up. This time - no lights at all.
No the red power light in the front comes on for a splt second the goes out
Posted on Nov 19, 2009
  • 8,617 Answers
Does the set do anything what so ever when you press power/ Are there any lights lit on the front at all?
Posted on May 29, 2008
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Wd-62825 takes a few seconds to turn on
the lamp may be showing its age or number of hours of use---typical on this set from cold turn on is up to 15 seconds.
Oct 29, 2012 | Mitsubishi WD-62825 62" Rear Projection...
Playstation 3 does not output to my Mitsubishi 62825. It has in the past. I've tried RGB and component. Neither work. Using the same cables it works fine with my girlfriends Sony Bravia. The tv has...
Is your girlfriend's television higher resolution? If so, the ps3 may be configured to output a signal that is too high for your mitsubishi. With the ps3 off, insert either the component or the rgb to the back. The turn on the main ps3 power switch so that the red led turns on. then hold down the 'power on' button. it will beep initially, then beep after about 3 seconds. This simply resets the output to the connected cable in a normal resolution.
If this fails go to settings>video output> and play around with the settings there. note you may have to do this on ur girlfriends tv to be able to see what you're doing...
Aug 26, 2011 | Mitsubishi WD-62825 62" Rear Projection...
No response from the TV when turned on. Slight hum but no green light flashing....
power supply or mainboard deffective..go to your nearest mitsubishi srvice center
Sep 07, 2010 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62825 Green Blinking light and TV won't turn on
I have the same problem with the green light blinking and the T.V will not come on. I have reset it and unplugged it and everything and still nothing. Can anyone help me
Aug 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Oct 29, 2007 | Mitsubishi WD-62825 62" Rear Projection...
WON'T TURN ON
try to see if you can do a self diagnosis test and if not Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... of lamp replacement.
Jun 16, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
