Question about Kenmore 24032\24036 Top Load Washer
Work good for washing but don't drain water - Kenmore 24032\24036 Top Load Washer
  • Kenmore Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 07, 2010
Whirlpool SM8281115
You probably have the end of the outlet hose too low to the ground it should be about half way up the back of the machine or fitted into a stand pipe.
http://selfix-uk.co.uk/under%20sink%20plumbing.html
or the water entering the machine will just siphon out
Mar 28, 2017 | Whirlpool Washing Machines
When it is on Eco wash the sudsy water drains out and does not return to the bowl so we have to use traditional wash ... it is a new machine ... I set the drain hose up as per operators manual i.e. maximum...
ECO wash cycles are never that successful, they are very picky and sometimes something as simple as the water hardness messes the cycles up, Also sometimes the cycles don't function quite as advertised.
The head height of the drain will also affect the ability for the operation of the ECO Cycle.
Mar 10, 2012 | Washing Machines
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
We have snked the drain line and put the water hose through the line and when we run the washing machine with no clothes in it the drain works fine. when we run the washing machine with clothes in it the...
Newer machines will eject the water so fast that older home plumbing may be too small to keep it from overflowing. We had no choice but to pay a plumber to install a larger drain to use the new HE washer I bought to replace my old one when the transmission went out. Then I had to fix the drywall after he ran new PVC to the larger drain further down the wall. I suggest asking how big of a hole they are going to make, and being prepared to fix that too.
Aug 10, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I don't know how to drain out the water (earlier than it should be) cause I'm having water pipe problem - URGENT help needed. thanks
Turn on the power button,
Touch the spin button once, then press start. That will drain the water out.
Good luck.
Jul 16, 2011 | LG Washing Machines
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Error code 20 will not drain water and don,t know how to open washer to check drain
What is your tecnical ability? According to the manual, it could be faulty wiring between the pump pressure switch and the control board. If the connections are corroded, or loose correct the wiring. If the wiring is good replace the pressure switch. If that doesn't work then control board needs replaced.
Let me know
Jan 09, 2011 | Frigidaire Affinity ATF7000E Front Load...
Water problems
If the washer doesn't fill properly, or if only one temperature of water fills the tub, something is probably keeping water from entering the machine or it's draining before the tub fills completely. Set the controls to the first wash cycle, and then try each water temperature setting. If both hot and cold water seem to be entering the washer with good pressure, water may be draining out prematurely during the fill cycle, through siphoning action. Be sure the drain hose's connection to the standpipe is at least 34 inches above the floor (otherwise, discuss the problem with a plumber). An air gap between drain hose and stand pipe that prevents backflow is also good to have. If hot works but cold doesn't, or vice versa: 1) Be sure both the hot and cold water faucets are turned on. 2) Be sure the supply hoses are not kinked. 3) Turn off the faucets. Unscrew the hoses from the faucets and drain them into a bucket. Hold the bucket under the faucets and test them to make sure they both work and have plenty of pressure (see HERE for information on replacing faucets). Screw the hoses back onto the faucets. 4) Unscrew the hoses from the inlet valves and clean the filter screens just inside them; these may be clogged. To do this, pry out the screens with a screwdriver (this can be difficult; the screens may be inside the valves), flush them under running water, then put them back into the hose. If the screens look defective, replace them. Then screw the hoses back onto the valves. Be careful not to cross-thread the hose threads when screwing them back onto the valves. 5) Call an appliance repairperson; there may be a defective inlet valve or a problem with the controls.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
