Question about Whirlpool Duet GHW9150P Front Load Washer
Knocks bad when spinning washer is level - Whirlpool Duet GHW9150P Front Load Washer
    Habit-Forming:
  • 84 Answers
Your bearing in the machine are done
Posted on Oct 07, 2010
Ftf530es knocks during spin cycle
Good Afternoon Amy,
I understand that your Frigidaire washer, model# FTF530ES, knocks during the spin cycle. I also see that the drum moves from front to back and not up and down. I suggest making sure that your washer is level from front to back, side to side, and from corner to corner. If after leveling you washer, the drum is still moving from front to back, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine why the drum is moving from front to back. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FTF530FS Front Load Washer
The washing Machine knocks during spinning
Easy fix: Readjust the riser supports and level the washer. Some washers have adjustable feet that screw up and down. Put a level across the top of the washer and when it is level front and back, the legs are in the correct position. Some units have auto-level adjustment meaning you have to pull your washer forward and bounce it gently back toward the wall and lift the Front in the same fashion. In some cases side to side adjustment by lifting one side up and then the other can do the same thing in adjusting the levels. Either way you must LEVEL the washer in order to STOP the rattle or bounce.
Dec 14, 2013 | Whirlpool Washing Machines
Drum is making a loud banging noise during spin, it is brand new
Some banging or knocking during the ramp up to spin speed in this washer is normal. It is difficult to determine whether your washer has a problem or not based on your description. This banging lasts for varying amounts of time until the load is balanced and the washer ramps up to the full spin speed. If the load can not be balanced on the first attempt, the washer will ramp down and then tumble and attempt again to ramp up to speed. This may be the same thing that you are hearing when your washer ramps up to spin speed. Since the washer does spin at the full speed, there is not likely a problem with the washer. The components are designed to withstand repeated vibration and reasonable banging or knocking. The washer will vibrate to some extent at high speed. If you feel that the vibration is excessive, I recommend that you check the stability of the leveling feet. Press down on the diagonally opposing corners of the washer to check for play. If the washer rocks at all when conducting this test, I recommend that you adjust the leveling feet to eliminate this play even is the washer is not perfectly level after making this adjustment. This may help reduce the banging and vibration. Other than that if it is brand new call the people who you purchased it from so you don't void any warranties by taking it apart.
Sep 08, 2011 | Washing Machines
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Loud knocking and vibration during spin
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer rattles and knocks when spinning
you either have a broken shock or the spider gear is gone,take off the bottom panel and check out the shocks,if it's the spider gear it's time for new washer,it's around 500 bucks for new gear,to much detergent used over the years eats at the metal
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3 washer started knocking and shaking during spin.
indicates that the tub support rods have failed at the air dampners
the fix is new rods from the service agent spares and a re levelling if the tub ,not the machine
Nov 20, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Knocking and rocking at lower spin RPMs
hi there......check that the installers removed all the transit bolts....these are used to hold the drum secure during transport....check that the balance weights on the appliance are secure.......
regards Sir Galahad
Aug 18, 2009 | Washing Machines
The washer comes to life on the spin cycle lol
IS THE WASHER LEVEL ? YOU'LL BE SURPRISED HOW MUCH THIS WILL EFFECT YOUR WASHER JUST PUT A LEVEL ON IT TO MAKE SURE IT'S PLUM
Apr 12, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
