Question about Toro Lawn Mower With Toro Power Tools
Brand new mower. I can empty the bag and restart it successfully 6 to 8 times. After that, I pull the cord and get nothing. If I leave it sit for an hour or more it will usually start again. There is no manual choke or bulb on this new model. Pulled the plug to check for any signs of "fouling" and saw nothing. After 40+ years of lawn mowers, this has been the worst on "out of the box"! GT
  • gthat Oct 07, 2010
    Does anyone know if this is a common complaint? If so...there must be ONE answer...not try A,B,C,D and so on.
  • 652 Answers
You need to clean out the bowl on the btm of the carb. Use some gas treatment to stableize the gas
Posted on Oct 07, 2010
  • 2,973 Answers
GT,
Please see if any ventilators are blocked by something. It seems that the mower get heated up and needs a rest after that. Or may be its HT coil gets heated up and needs some cooling. When it dies out, please check if there is spark coming in the spark plugs. If no then it is the HT coil. Needs replacing and as it must be under warranty, it should be replaced free. If there is spark (blue spark jumping the plug points) then it must be the carb that needs fixing. The air and fuel jets to be adjusted.
Hi I have a brand new Victa Mustang with the Honda GCV160 4 stroke. Hve fuelled up, added oil, turned on fuel tap but it won't start. Any ideas?
Has it been sitting? Has the gas been sitting? I'm sure the carb is all clogged and gummed up with stale gas and dried ethanol. Buy a new carb, GCV160 carbs are like $20 shipped on eBay.
Dec 09, 2014 | Honda Garden
Brand new craftsman 190cc lawnmower pull cord will not pull out
New mowers some times comes with a safety block on the blade and this has to be removed before you can turn the blades
Jun 30, 2014 | Craftsman Garden
Dose not restart when hot
Adjust valves. If not losing compression
Nov 29, 2013 | Briggs & Stratton Garden
Lawn mower doesn't start
you have unseated valve seats the hotter it gets the wores starting get this a warranty repair
Feb 24, 2013 | Briggs & Stratton Garden
Pull cord hard to pull and won't reel back in
should never pull cord unless correct amount of oil is in it !, My advise take back to sears and buy a Toro ! Did you have the blade break lever pulled back ?
Oct 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Not getting any spark
Clean the Plug and replace the Seafoam gas with fresh. Althiough the Seafoam is a cleaning agent, it cuts back on the gasolines octane and it can slightly foul plugs.
Aug 07, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
I have a Troy-Bilt Mower - Model 834. It has a Honda GVC 160cc engine. It is supposed to start after two pulls when cold and did so since I bought it in 2006. But, just recently it takes 6-10 pulls to...
sounds like the throttle cable has slipped on the side of the engine if they dont pull the choke all the way on they wont start too well. one way to find out is take your air cleaner and outer cover off so you can see in the front of the carby the put your throttle on start/choke position the choke butterfly should be closed if not check your cable.
Jul 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Apr 25, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
