Question about Refrigerators
Light keep on flicking on and off
inside light keeps on flickering on and off but will not stay on when the door is open? fridge model is Hotpoint FF175B.
What can it be? a faulty bulb?
Help appreciated Thank you
    Problem Solver:
  • 14 Answers
Unplug the frig to remove power. Unscrew the bulb. Check the nub on the bottom of the bulb to make sure it is not flattened. Use needle nose pliers to grab the center tab of the bulb socket and pull outward slightly so bulb will make better connection. Could be a faulty switch or bad connection in the wiring.
Posted on May 29, 2008
Both orange Light on top of hotpoint fridge keep flashing
Whats happen is the machine has gone into stand by because the doors was left open to sort it out what you need to do is
turn the freezer knob to off then turn it back on again this should restore it.
Apr 12, 2016 | Hotpoint Refrigerators
Fridge light not working
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
Feb 28, 2015 | Hotpoint Refrigerators
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Apr 26, 2014 | Zanussi Freezers
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
Jan 13, 2012 | Refrigerators
Fridge light takes 2.5 sec to come on
Hi!!!
Have you cleaned the switch actuator? It is usually located on the door frame since it is activated by the door. Some times accidental spills will keep the switch from working correctly.
Good Luck
Mar 11, 2010 | Refrigerators
Light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
Dec 08, 2009 | Refrigerators
Fridge Frezer
Hi I am the lady with the freezer that keeps icing up at the bottom and then dribbles water from the door when you open the door. Did you say to pull the freezer out and do something at the back of unscrew the little panel that is inside the freezer at the bottom?
Jul 14, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint FFS70 fridge/freezer
This is normal  the red light tells you that there is a slight of decreased in coldness .Eventually the red light will  disappear after the refrigerator has recollected it's coldness... in 24 hours approximately .....Jack Arevian.(.Aleppo Syria).Refrigeration Engineer...........
Oct 16, 2007 | Hotpoint FFS70 Bottom Freezer Refrigerator
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
175 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
