Question about Fuji FinePix F700 Digital Camera
The pictures started to have light colored patches around them. Now when I turn on the camera, the screen is fuzzy and dark gray. The last ones I downloaded had either very white content with occasional pinkish blotches and the last several are just all black.
    Problem Solver:
  • 9 Answers
Try to clean the lense with a soft cloth. But before you wipe it, breathe out through your mouth into it to create a thin film mist then wipe it.
Posted on Oct 07, 2010
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Screen is the color blue?
That isn't convergence that does that. There are "screen" trimmers, if someone has messed them up you can get all one color, but the usual cause is the picture tube going bad. The screen trimmers are on the PC board on the gun (narrow) end of the CRT. Some trimmers are color drive and others are color black level, or "screen". Don't adjust the color drives, it is a delicate balancing act to get them right. Find the one labelled blue and turn it down. If all you can get is too dark, turn the red and green up, just enough to see a dim color haze in a blank picture. Balance them out so the haze is gray. Then turn them all down just a hair so the screen is just black. Then try a picture. If you can't get gray on a blank screen then go to the high voltage transformer (the one that can kill you if you touch the wrong part) and adjust the "screen" control on its side up (it adjusts all the colors together). If you still can't get gray, one or more of the color guns is weak, and you may as well chuck it.
Of course it could also be a bad blue drive transistor, but fixing that takes more expertise than you can get from a forum.
Actually, just getting the TV open and propped up so it doesn't fall over is a job in itself...
Jan 04, 2014 | Samsung PCL5415R TV
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
LCD screen Olympus Stylus 1010 snowy and fuzzy with lines
This is a issue with just the LCD it needs to be replaced.
May 25, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Shutter won't open when turned on. Screen is gray & alarm sounds
It sounds as if when the camera was dropped it impacted the image processing chip inside of the camera thus why the LCD screen appears gray in color. You may want to call Olympus and discuss repair options. Their telephone number is 800-622-6372 option 2 and then option 3.
Nov 19, 2008 | Olympus Stylus 1010 Digital Camera
Dark fuzzy picture when tv is first turned on
I am having a similar issue. Did you ever figure out the problem??
Feb 29, 2008 | Televison & Video
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Fuji FinePix F700 Digital Camera Logo
59 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
