Question about JBL Car Audio & Video
Need factory wiring diagram for 1992 ford explorer w/ amp and pre-amp and sub-woofer
SOURCE: Alpine Cdm- 7834 wiring help
bypass amp and run new wires to all speakers ,,,, will sound better .
Posted on Jun 17, 2008
  • 8 Answers
SOURCE: stereo system in 1994 ford explorer
I had this same problem.Took it to a friend and we bypassed the amp completely and ran new wires to all the speakers.
Posted on Aug 29, 2009
Benimur
  • 6966 Answers
SOURCE: trying to install factory cd-cassette
Hi and welcome to FixYa,
On your need for the radio wiring of 99 Ford Explorer and a 96 Ford Crown Victoria, see below wiring scheme:
Confirm with a voltmeter on the +12 and an ohmmeter for speaker continuity.
Good luck and thank you for asking FixYa.
Posted on Oct 30, 2009
  • 773 Answers
SOURCE: PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Posted on Dec 15, 2009
  • 306 Answers
SOURCE: i need wiring instruction for
http://service.us.panasonic.com/OPERMANPDF/SBW500.PDF try this... allthough generic it should work for you
Posted on Feb 11, 2010
Testimonial: "Thank U so much! Your answer 2 my problem helped me tremendously!!! You all R GREAT ! tiredawg"
Can i wire non amplified mid-range/tweeter speaker's on the inside of an altec acs250 sub woofer directly to the woofer speaker
Probably not. Somewhere there is a filter (crossover) that only sends the lower frequencies to the sub-woofer driver. Where that filter resides (either in the pre-amp, receiver or sub-woofer enclosure is yet to be known).
Oct 27, 2016 | Audio Players & Recorders
Someone cut the factory harness out of my 92 Ford explorer xlt so it hard to install aftermarket radio I need the color codes for the wires
I have enclosed two wiring diagrams, one is for base radio and the other is for premium radio.the way to know which one you have is that the base radio does not a have an amp connected to it. you will see it in the wiring diagram.hope this is helpful. good day.3_9_2012_5_30_46_pm.gif3_9_2012_5_30_58_pm.gif
Mar 09, 2012 | 1992 Ford Explorer
Were is the sub woofer tie into at.
You should have two (or more) RCA plugs on the back of the deck that will act as pre-amp outputs for subwoofer and speakers.
Failing that, your wiring harness should have come with a wiring diagram that will let you know which is the subwoofer output.
Failint THAT, the deck itself should have a wiring diagram on the bottom or side telling your which wire is which.
And if that fails, Your deck may not have a subwoofer output. Just attach your sub to the amp pre-out like everyone else.
May 11, 2011 | Pioneer DEH-2400F CD Player
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
Jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Mar 15, 2010 | JBL BP1200.1 Car Audio Amplifier
'04 Nissan Sentra S factory installed subwoofer wiring diagram
A FACTORY INSTALLED AMP/SUB WILL BE WIRED INTO THE VEHICLES FACTORY WIRING JUST AS ANY OTHER COMPONENT. YOU WOULD THINK THAT YOU WOULD FIND THICK POWER AND GROUND CABLES ALONG WITH RCA CONNECTIONS AS YOU FIND WITH MOST INSTALLS.NOT THE CASE HERE.YOU MUST FIND THE HARNESS THAT HAS THE POWER AND GROUND CONNECTIONS ALONG WITH THE INPUT WIRES FOR SOUND. YOU MUST OBTAIN A VEHICLE SPECIFIC WIRING DIAGRAM THAT HAS THE WIRING FOR THE SOUND SYSTEM PACKAGE THAT CAME WITH YOUR VEHICLE. YOU MUST THEN WIRE IN THE BLUE REMOTE TURN ON LEAD FROM YOUR UNIT TO TURN THE AMP AND SUB ON WITH YOUR RADIO AND NOT YOUR CAR BATTERY. YOU WILL ALSO NEED TO FEED SOUND TO THE AMP USING ONE OF THE REAR OUTPUTS FROM YOUR RADIO.
Sep 05, 2009 | Car Audio & Video
Stereo system in 1994 ford explorer
Aug 25, 2009 | Dual XDMR7710 CD Player
2002 Ford Explorer Sport - Blown Subwoofer
yes you can replace it but is gonna be costly,because your gonna need a box plus the new woofer,any after market will not fit plus will require more power ,so your gonna need a bigger amp,plus wiring etc,,,,,re consider using a factory sub again or replace the sub plus the amp..check the replacements and amps at crutchfield..good luck
Jul 10, 2009 | Car Audio & Video
1999 explorer stock subwoofer
I would be very proud of that truck as the sub that came with the truck was only a 8". The only one that works is the factory model as it is a 1 1/2 - 2 ohm speaker; replacements are 4ohm. You will have to replace the amp as well if you put in an aftermarket sub. Oh and apparently the amp will have to have "speaker level" inputs as opposed to pre-amp inputs. I have a 1999 Eddie Bauer wih a blown sub and I'm trying to decide what to do as well. The speaker is $400 with tax in Canada! Good luck.
Mar 06, 2009 | 1998 Ford Explorer
Car Audio & Video Logo
729 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
