Question about Samsung HLP4663W 46" Rear Projection HDTV
Need Help locating correct Samsung HLPColor Wheel number
Samsung HLP4663WX / XAA
What is the actual color wheel part #? I cannot seem to locate it on-line anywhere.
    President:
  • Samsung Master
  • 1,779 Answers
Part # BP96-00674A
Posted on Jun 16, 2008
  • 2,335 Answers
Check this site for the color wheel.
You find also find on how to install it by check this post and clicking here.
Posted on May 29, 2008
  • backwardsk Dec 14, 2010
    You can check here for the models that fit color wheel part # bp96-00674a if that helps - bp96-00674a color wheel replacement
I have a Samsung model HLP4663wx/xaa and I just recently changed the color wheel assy. I am on my 3rd bulb, I also changed the ballast recently. Now my problem after the color wheel install is the picture...
if you replaced the ballast your self you may have overlooked a plug to be plugged in, i would take it apart again and check that all plugs are as they should be, for the problem started right after you replaced the lamp power supply. if a repair shop serviced the unit you may be part of a scam and if so get a 2nd opinion from a different repair shop
Jan 10, 2012 | Samsung Televison & Video
HLP4663wx/xaa Fan or Color wheel making noise? I first noticed it within the last week making noise when turning the set off. Now it's continuous. Could hear it slowing down on power off, constant...
A fan like noise is 98% of the time the color wheel.
Wheel turns at over 12,000 rpm and common failure is "fan like sound or even grinding sound".
When these sets first came out if the high pitched sound started women who have better hearing in that range usually hear it first.
If wheel really fails it will shatter and set will not come on----a grinding sound may be noticed just before total failure.
SD TECH
Oct 17, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
What is the difference between a color wheel and a color conversion kit on a Samsung HLP4663wx
HLP4663WX is a DLP which has a color wheel. The DLPs dont have convergence circuits since there is only one light source. Projections with three CRTs have convergence which is the alignment of all three CRTs ( Picture Tubes)
Jan 05, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663WX/XAA picture went out, started making strange noise, all lights on power button came on.
Sounds likea bad color wheel to me, or possibly a lamp has blown. If the noise is a humming sound--it is the CW--if you hear a "sound like a sizzle, for a few seconds and then normal, and this repeats a few times--the lamp has blown.
Oct 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Replace Color Wheel
go to you tube there is a video there that shows you how to replace it you will find it just to the left of the lamp when you pull it out
Apr 12, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Color wheel problem on my HLP4663WX/XAA
The color wheel is not working, and failed in green. The best case is a cable is loose, color wheels typically have a two pin power connector and a ribbon cable for phase locking. If it is not these connections, you will not be able to fix it yourself.
Sep 21, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Blinking lights
Sounds like the color wheel. Check samsungparts.com for a replacement. Check the video on youtube of a guy fixing his color wheel to see if its something you want to tackle. I changed mine... a drag, but not too awful. Ran about $100.
Sep 01, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
Feb 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W Color Wheel
 The color wheel that goes in an HLP4663WX/XAA is:
  BP96-00674A
 This is the correct color wheel.
Oct 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
241 people viewed this question
Jerry Greenberg
Jerry Greenberg
