Question about Vacuums
Sewing machine necchi model # 534fb the needle wont go up and down. can u help me?i lost my book. tk yu
jyackle5
  • 8197 Answers
SOURCE: I need a manual for
You can find all the manuals for many different sewing machines and download them from the following web site.They do require some fee though.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Necchi.htm
Or you can go to this link to learn how to thread.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_534_535_threading_Diagram.htm
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 02, 2010
alpug
  • 1961 Answers
SOURCE: We have a Necchi model
Inspect the "feed dog", this is the spiky plate under the foot. It is the one that drags the fabric or material. Check if its already worn out and might need replacing. See also if your unit is equipped with adjustment for feed dog. Shift it up.
When you feed a fabric material, start on the edge. a small cut on the edge will make it easier to feed the material over and under the foot.
Alp
Posted on Sep 12, 2010
  • 218 Answers
SOURCE: in have a Kenmore sewing
check with http://www.sewingmanuals.com/
Posted on Mar 20, 2011
  • 517 Answers
SOURCE: sears kenmore 158.321 sewing machine
Good day!!!
If the problem is always broke the needle..
The problem could be the correct timing of the machine please adjust the timing of your sewing machine to fix your problem...
Thank you and good luck..
Posted on Jun 24, 2011
  • 244 Answers
SOURCE: In my Singer Sewing Machine
There could be several things causing this.
First, be sure the bobbin is in the bobbin case correctly. There is usually a line diagram showing the correct placement or you can check the owner's manual.
Second, make sure your needle is inserted correctly. If it is not completely set in the housing, this can prevent the bobbin thread from being caught by the hook. The groove in the needle should be ffacing toward you to assure that the thread interacts with the hook.
Third, be certain the upper threading is correct...passing through all thread guides and correctly through tension and take up lever.
Finally, make sure the bobbin case is free of lint. The machine brush that came with the machine will clean this area well.
I hope one of these suggestions helps you solve your problem. If so, please come back to Fixya and rate my advice!
Posted on Jul 24, 2011
What is my needle hitting that breaks it on my singer sewing machine 247
sounds like the machine is out of time . best solution is to take it in to be repaired .
Oct 11, 2014 | Singer Tension Assembly, Fits: Models 242,...
My Futura 900 machine is locked up tighter than a drum. How can I fix it?
this should be in sewing not vacuums. Did you find the bit of needle that broke off? It might still be in causing problems. turn machine upside down to free any bits that might be hanging about.
Jul 03, 2014 | SewShop.com Singer Model 900 Futura...
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
I've lost my user manual for my necchi sub22 sewing machine and can't for the life of me remember how to wind the thread onto a bobbin. Not a big issue, but it's really bugging me, because I...
You could email: spares@aeuk.co.uk and ask for a manual or call (+44)1322 291137 x 2 between 10:00 and 14:30
Or (Thanks to an article 10 months ago from Farmerbear) you could go to allyint.com
They are the sole US importer of the Necchi machines and I believe they stock replacement manuals. Their number is: 1 800 525 9987 ex 20
Jun 30, 2011 | Vacuums
I have a Necchi Renaissance 2 sewing machine that I can't seem to get accessories for I live in South Yorkshire, any ideas?
You could go on line and have the parts send to you. Here a web site that will help you buy the parts.
http://www.sewingstyle.com/Necchi-Sewing-Belts.html Hope that this will help you.
Jan 25, 2011 | Vacuums
I need a manual for a NECCHI Model 535FASerial nember 088549 sewing machine
Sep 02, 2010 | Vacuums
The presser foot is stuck in the down position on my sewing machine. The lever goes up and down but the foot will not move. Help! I have an old Kenmore 22 sewing machine. Probably got it around 1990. The...
if you open the left end of the machine .. look inside above the needle and to the back .. you will see a pivot bolt that has either come loose, broken off or fallen out .. replacing that bolt should fix the problem ..
Jun 05, 2010 | Vacuums
Vacuums Logo
42 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
