Microphone problem mic B is not making a sound, when i put on the correct frequency with the receiver is skips from9 to 12 up to 13 or 14 dB, ive noticed when both mics are correctly working they are at 36 dB consistently. I ve checked cables and batteries, think its a problem either with that side of receiver or the most likely the microphone. Please let me know what i can do, or how i can get it fixed, im a karaoke dj and is pleased with the mics and want to continue using the pyle pro mics, the model kind is PDWM9300 UHF dual wireless system purchased 8 months ago.
  • bwwoods53149 Jun 01, 2008
    I have a Telex M560 - haven't used it in a while, can't figure out how to use it now. I go in sounds and see that it is registering - but how do I save the sound file and listen to it. Need it for kid's school project.
Hi i know this is old but would you like to sell it ?
isit a beyerdyamic m560?
Posted on Mar 07, 2009
I have 2AKG UHFHT40ULTRA HIGH FREQUENCY handheld transmitter microphone , why when I turn them on they blink on and then notning ?
Okay, before going any further, let's just check....
  1. Along with your wireless mics, you have an AKG wireless receivers (e.g. WMS40 mini2), right?
  2. You've checked that mics and the receiver all work on the same frequency?
  3. You have connected both outputs from the WMS40 mini2 to individual mic channels on a mixing console?
Let's recap....
  • The AKG mics aren't going to work unless you have one of the matching receivers
  • The receiver has to be the correct type. This means if you want to run two mics at the same time, then you need a dual channel receiver (WMS40 mini2) otherwise they'll block each other. So, if you only have a single channel receiver (WMS40 mini) then you can only run one mic at a time, not two.
  • The mics and receiver have to be on the same frequency. They make it easy by colour coding the hand mics and the receiver. If the colours are different then they're working on different frequencies that are not compatible.
If you're good to go on all the above then the next stage is just the connection and set-up of the mics, receiver and mixer.
Since the mics are a pretty straightforward On/Off switch affair then there's not much to say there. Just make sure you maintain the correct distance for to ensure the wireless signal spreads out properly. It needs a minimum of 3m (about 10ft) distance between the mic and the receiver.
The receiver is straightforward too. It needs power, so make sure you plug in the mains adapter. The front LEDs give you the status of the signal. There's only two lights per channel, so it's easy to understand. RF OK confirms that the receiver is picking up the mic signal, so this one should be lit. AF CLIP let's you know when there's too much level from the singer/speaker. This could be that the receiver's volume control is set too high, or the singer/speaker is holding the mic too close for the volume they're producing.
The receiver's volume control needs to be adjusted fully counter clock-wise if connecting to a mixer by a balanced audio connection. If you're running in to the line level input, then the dial needs to be turned fully clock-wise.
The signal connection going to the desk should really be made with balanced leads. Jack to jack (TRS) or jack to 3 pin XLR will both maintain the noise suppression benefits of the balanced audio connection.
The rest is how you set up the mixer for the signal. Good luck.
Sep 14, 2014 | Audio Players & Recorders
Check to make certain the mic and the receiver are on the same frequency range. The frequency range will be provided on a sticker on the mic and the receiver.
Feb 10, 2014 | Shure ULX P4 BETA 58A Professional...
Why won't wireless mic turn on the "Ready" light on receiver?
Make certain the mic and the receiver are in the same exact frequency band. There are stickers on both products that list the frequency band.
Apr 27, 2012 | Shure UT2 / 58 / PG58 Professional...
Can anyone please tell me how to use a shure sm58 radio antenna wireless microphone or manual as ive just purchased this of ebay and no instructions came with it so a little lost as no sound coming from...
Shure SM58 is not a wireless microphone, so clarify me the exact model for your wireless device in order to help you.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 06, 2011 | Shure SM58 Professional Microphone
I got a new mic and I cant get it to sync to my reciver it is a PGX4 and the mic is a PGX2
The mic is probably in a different frequency band than the receiver. Look at the stickers on the receiver and the mic to make certain they operate in the same frequency range.
Jan 23, 2011 | Shure PGX-2 Wireless Handheld Microphone...
My mic seems to pick up internal noise even when muted
Hi, You can check you the connectios or the mic. remember that the mic is too sensitive, you can adjust it with the nobb on the mic by putting it on o -dB and reduce the highs on your mixer or EQ to reduce hiss sound.
But fisr check the connection properly to see if when muted, is muted properly.
Take care.
Frequency settings on se2200a
It is a pad..which is a switch that will 'reduce' sound level or volume which in a nutshell is useful for recording loud instruments..So switch to -10 db if placing the mic fairly close to say loud drum or horns..etc..
May 30, 2009 | SE Electronics SE2200A Professional...
Receiver is making a humming noise when turned up
your mic is misup that happein to my mic to so get i new one !!!!!!!!!!!!!!!!
Apr 14, 2009 | ElectroVoice Electro Voice RE-97TX...
Wireless Microphone low volume
The PGX1 bodypack has a switch on the side to set the gain. Make certain that switch is in the "mic" position. Otherwise, simply turn up the volume on your mixer.
Jan 24, 2009 | Portacom Porta-Com COM-60FC 6 Headset...
274 people viewed this question
