Question about Hitachi 57F510 57" Rear Projection HDTV-Ready Television
Can't get full screen. tried all aspect selections. also color is off. can't get it to adjust. magic focus dosen't help. any suggestions?
  • Hitachi Master
  • 8,457 Answers
Magic focus button don't work.Colors lines R,G,B mis alignment,have colors shadows picture or 3D pictures.The tv have a problems known as a convergence problems,it dead.The tv convergence board it dead,must require replacing 2 STK convergence ICS and some or all it resistors to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Posted on Oct 07, 2010
How do i adjust the magic focus?
  • Press "Menu" on the remote select the "Magic Focus" option in the Video menu or press the "Magic Focus" button on the front panel to adjust the convergence of the three picture tubes that create the proper color for the picture. Pressing the button on the TV initiates the automatic adjustment, and accessing the feature through the Video menu allows you to choose automatic or manual adjustment, though the "Automatic" setting must be selected for the button on the front of the TV to begin the process.
  • Aug 04, 2011 | Hitachi 53UWX10B 53" Rear Projection...
    Adjust the color in a hitachi 43F300
    The below convergence procedure was copied from: http://www.espnhd.com/voice/showthread.php?t=3736
    Manual Convergence for the Hitachi
    1) Receive an NTSC signal.
    2) Press Magic Focus to begin magic focus
    3) Press magic focus again during the magic focus process to get the ?stop? screen
    4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
    the service grid (64 point grid)
    5) When you first get in here? I believe red is the selected color by default (it is flashing).
    6) To choose other colors to converge, use the following buttons on the R/C:
    a) ?STATUS? - Green
    b) ?0? - Red
    c) ?ANT? - Blue
    7) Start from the center of the screen and work your way out on one color at a time. I adjusted red across the
    whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
    may want to go back and adjust some red again? etc. until the convergence looks good.
    (a) Use 4, 6, 2, and 5 on the R/C to move the cursor position(dotted lines).
    (b) Use thumb stick to move the convergence point color.
    ** There have been other posts in here to tape together the color filters found in the Avia DVD to help converge
    lines more easily. I have used this method, and it works well for adjusting to a greater detail. Basically, you put the
    red filter next to the green and adjust your red to the green line both horizontally, and then vertically. Then you do
    the same with the blue next to the green. Some people recommended you should be at normal viewing distance. I
    did mine from just a few feet back from the set. Maybe my eyes aren?t as good? maybe I just felt like it worked
    better this way. There are some other posts also recommending using binoculars. I think it?s great that people
    suggest things to make the process easier? but my girlfriend would think I was insane if she saw me with
    binoculars on the couch adjusting the convergence. I don?t know? whatever works best I guess.
    8) I did not adjust the green at all. I use the green as the guide and did not adjust the location of any green point.
    This is highly suggested unless you have geometry problems.
    9) When going along the lines and adjusting, you may run into the problem of getting an ?S? curve on the line.
    You?ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the
    line between the points will not straighten out (it bends between the points). To fix this, the manual recommends
    going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is
    also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in
    (13x9) mode (64 point). If you have serious problems, the grids work as:
    3x3 - ?coarse?
    7x5 - ?medium?
    13x9 - ?fine?
    10) To get to each of these patterns use the following on the R/C: (only if you need to)
    1. (3x3) Press ?STATUS? 5 times (only works when DCU is in uncorrected state)
    2. (7x5) Press ?0? 5 times
    3. (13x9) Press ?ANT? 5 times
    11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point? depending on where
    you start, work your way up, and always finish on the 13x9
    12) When finishing up the 13x9 mode, to get additional ?grids? on the edges of the screen, press the PIP CH button
    on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence
    as necessary. To exit, press PIP CH again.
    13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed
    to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write
    displayed data to ROM.
    14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
    15) Green dots will be displayed when operation is completed.
    WARNING: YOU MUST DO THE FOLLOWING STEPS TO COMPLETE MAGIC FOCUS
    INITIALIZATION!!! THERE HAVE BEEN MANY POSTS THAT PEOPLE HAVE HAD PROBLEMS
    WITHOUT DOING THIS STEP BECAUSE THEY LOOSE MAGIC FOCUS!
    16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
    17) Press PIP MODE and then PIP CH to initialize Magic Focus. The initialize operation starts and several
    windows appear during this operation. It takes about 30 seconds or less.
    18) When green dots appear, initialize operation is finished.
    19) Turn power OFF.
    21) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just
    to make sure the magic focus still works (and that you did the last few steps properly)
    Hope this helps
    Dec 15, 2007 | Hitachi 43F300 43" Rear Projection...
    We cannot get the color to align. It appears like there is a blue or yellow background around words
    If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
    If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
    You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
    Mar 02, 2011 | Hitachi 57F500 57" Rear Projection...
    Magic focus error Hitachi 52
    The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
    SD TECH
    Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
    Convergence problem, I think
    i think you need a tech .because all the users adjustment were tried.
    May 28, 2009 | Hitachi 57F500 57" Rear Projection...
    I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
    Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
    1. Receive an NTSC signal.
    2. Press Magic Focus to begin magic focus
    3. Press magic focus again during the magic focus process to get the “stop” screen.
    4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
    5. When you first get in here? I believe red is the selected color by default (it is flashing).
    6. To choose other colors to converge, use the following buttons on the R/C:
    · “STATUS” - Green
    · “0” - Red
    · “ANT” – Blue
    ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
    7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
    · Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
    · Use thumb stick to move the convergence point color.
    Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
    3x3 – ‘coarse’
    7x5 – ‘medium’
    13x9 – ‘fine’
    1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
    2. (7x5) Press “0” 5 times
    3. (13x9) Press “ANT” 5 times
    11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
    12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
    13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
    17) Turn power OFF.
    18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
    Mar 21, 2009 | Hitachi 43FDX01B TV
    DOUBLE IMAGE HITACHI ULTRAVISION TV
    Ok, I would suggest before you buy anything from anybody is to try to do a manual convergence.
    a) ?STATUS? - Green
    b) ?0? - Red
    c) ?ANT? - Blue
    3x3 - ?coarse?
    7x5 - ?medium?
    13x9 - ?fine?
    19) Turn power OFF.
    Oct 27, 2008 | Televison & Video
    Convergence ICs
    Well if you are not a repairman you should not do this kind of job yourself.
    If you decide to service your TV, remember to keep it unplugged for one hour before working on it.
    Check this link here to find sellers for the kit and illustrated procedures.
    Here I am reporting convergence procedure from website above.:
    " Manual Convergence for the Hitachi
    a) ?STATUS? - Green
    b) ?0? - Red
    c) ?ANT? - Blue
    3x3 - ?coarse?
    7x5 - ?medium?
    13x9 - ?fine?
    19) Turn power OFF.
    to make sure the magic focus still works (and that you did the last few steps properly)"
    Perform full convergence procedure before replacing ICs.
    To know if an IC has blown you should test the small fuse at the base of the IC.
    Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
    Blurred picture
    try the focus adjustment knob on the back of the flyback transformer....if that does not work...order a focus block
    Feb 03, 2008 | Hitachi 53UWX10B 53" Rear Projection...
    Hitachi 43FDXO1B Convergence?
    Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
    · “STATUS” - Green
    · “0” - Red
    · “ANT” – Blue
    3x3 – ‘coarse’
    7x5 – ‘medium’
    13x9 – ‘fine’
    17) Turn power OFF.
    Jan 13, 2008 | Hitachi 43FDX01B TV
    Hitachi 57F510 57" Rear Projection HDTV-Ready Television Logo
    93 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
