Question about Nextel Cell Phones
How do you change the faceplate on the nextel i95?
BASIC disassembly of your phone(i60/i90/i95)
This ONLY covers unscrewing the housing and splitting it open? that ALL. You'll need a T-8 torx driver for this.
Step 1: Turn you phone off, turn it over, take off your battery cover, take out your battery, and take out your SIM card. Be careful with your SIM card. Unscrew your antenna, remove it, and take out the metal antenna tube.
Step 2: Get your T-8 torx. Unscrew the THREE torx screws in the battery compartment. They are located in the bottom two corners and in the top left corner of the battery compartment.
Step 3: Peel back the right hand side of your ?Nextel? sticker just above the battery compartment. Peel it back ONLY A LITLE, until you expose the fourth torx screw. Use your T-8 torx to unscrew it.
Step 4: Carefully separate the two halves of the housing. BE CAREFUL, and keep in mind that at the top of the phone (near the flip hinge) there are cables still attached (the flip ribbon cable and the headphone jack). You will not be able to separate the two halves of the phone body all the way and will want to make sure to keep the top part of the housing relatively close together. If you screw up and damage the cables up there? don't try to blame us? we warned you.
Step 5: Do whatever it is you wanted to do that required you to split apart the housing in the first place (e.g. replace a keypad, PTT buttons, etc.), put the two halves of you phones body back together (carefully aligned) and screw the torx screws back in.
Step 6: Put your antenna, SIM, and battery back in, and you're done. Enjoy!
**Now let's talk about the flip. This ONLY covers the removal of the front and inside lenses of the flip. If you want to remove your flip completely, or remove the LCD of the i90. SEARCH the forum for info on how to do that. You'll need a T-6 torx, a SMALL flat-head screw driver, a hobby knife, and a blow-dryer for this.
Step 1: _This is optional, but is ideal for those nervous people out there who don?t want to take any chances. Remove your antenna and battery but put your battery cover back on.
Step 2: FIRST, open the flip. With the phone facing you (as if looking at your screen), look into the gap between the flip hinge and the phone body in the very center of the flip's hinge. You're going to see a small slot in there. Remember that slot? it's important.
Step 3: Close the flip and turn on your blow-dryer. Keeping the dryer about 4 inches from the surface of the front lens (the blue thing on the i95 or the silver thing on the i90) heat up the lens surface. Keep your blow-dryer moving around? DON'T concentrate it in one spot, you'll end up melting something. All you want to do is soften the glue a little. You don't need to use the dryer for too long to accomplish this. A minute or LESS should be fine, use your GOOD judgment.
Step 4: Once you have heated up the front lens enough to soften the glue underneath, quickly open the flip and use your small screw driver and poke it through that slot we talked about in step 2. You are pushing on the back-side of the front lens when you do this. BE GENTLE! You should be pushing the top of the front lens away from the top of the flip. Manipulate the phone in your hands as necessary so that you can hold the top of the front lens away from the phone. Remove your screw driver and close your flip (careful not to let the part you pushed away slip from your grip.)
Step 5: GENTLY pull the front lens away from the flip a little bit and use your hobby knife to cut away at the glue. BE CAREFUL not to knick or cut ANYTHING EXCEPT for the glue when you do this. In this process you will cut a little, and pull a little further away, cut a little, and pull a little further away. Continue this until you have completely removed the front lens. Once completely separated, make sure little to no contact is made with the glue on the back of the lens or the front of the flip. The more you touch it, and/or the more **** that falls onto it (dust or dirt or whatever) the less sticky it will be.
Step 6: Use your T-6 torx driver to unscrew the four torx screws on the front of the flip. These screw hold the inside flip lens down, so once they are out, be careful when you open your flip.
Step 7: Open your flip and gently remove the inside lens. BE CAREFUL. On the i95, the LCD is NOT glued to the inside of the flip. It is held in by the inside flip lens. You'll need to GENTLY remove it from the lens. If you're not careful.. you'll damage your ribbon cable and be screwed.
Step 8: Once your done doing whatever it is you wanted to do that required you to take your lenses off in the first place, just reverse the processes in step 7 and step 6 to attach your inside flip lens again. Then simply pres your front flip lens firmly back in place. If you were careful, the glue should be undamaged and would be PLENTY strong enough to hold your lens securely in place. Presto, you're all set! Enjoy!
Posted on May 29, 2008
How to change the faceplate of a samsung s7330
  • Locate the small plastic tab on the top of your Samsung phone, located in the groove between the faceplate the main phone body. This tab is very tiny, only about one-sixteenth of an inch wide.
  • 2
    Press on the plastic tab with your fingernail.
  • 3
    Continue holding down the plastic piece while sliding the faceplate off the top of the phone. The faceplate only slides off from the top, so don't try to force it in a different direction.
  • 4
    Release the plastic tab.
  • 5
    Line up the new faceplate with the top portion of your phone then slide it downward until it latches into place. You'll typically hear a soft click when the faceplate is secure. When properly placed, the new faceplate should not be able to wiggle or slide unless you press down the plastic tab once again
    Read more: How to Change a Samsung Phone Faceplate ' eHow.com http://www.ehow.com/how_5146822_change-samsung-phone-faceplate.html#ixzz17o6dpgG0
  • Dec 11, 2010 | Samsung S7330 Cell Phone
    Motorola i95cl
    unfortunately the i95 uses a 32k sim card and your i355 uses a 64k card...
    Apr 13, 2009 | Motorola Mobility i95cl Cellular Phone
    I HAVING TROUBLE UNLOCKING MY PHONE
    http://www.tanbigo.com sell:
    NEXTEL IC902,IC502,IC402,I930,I885,I880,i876,i870,i860,i850,i836,i833,I830,
    i760,I730,I95,I90,I60,I530,i335,I580,I265,I670,I560,I205,i450,i455
    Housing/mainboard/flex cable/lcd/lens/keypad/spare parts /battery/rotor/flip
    if you are interested in our oem products,please contact us.thanks
    We look forward to have a pleasant cooperation with you!
    Tanbigo Industry Limited
    Email:Jack@tanbigo.com
    MSN:Jack@tanbigo.com
    skype:jack881138
    Jul 02, 2008 | Nextel i730
    I95
    changed phone. Had broken boost and took sim card out and put in a I95 cl. wrked for about 7 hours and then nothing. I know that it is a series numeric number and then something.
    Please help,
    I know it it a serious situation. But please There is money to be made if ya know what I mean????!
    Mar 15, 2008 | Nextel i95cl
    Un lock my nextell phone
    http://safemanuals.com/ look in manual if need one u can get one on this site. if this helped let me knoe by rateing me.
    Jan 12, 2008 | Motorola Mobility Nextel i90 Faceplate...
    Unlock my Motorola i836
    plz help me solve my problem.
    i want to unlock my motorola i836
    Oct 17, 2007 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
    I cant change a setting
    go to Settings > Advanced > Reset to Defaults > this will delete all that crap. www.cdphonehome.com Nextel Repair Parts For almost all Nextels.
    Jan 20, 2007 | Nextel i860
    Both of my interior and exterior screen don't work..
    you can buy a new flip > or change the flex cable * I would suggest get a new flip. www.cdphonehome.com Nextel Repair Parts For Most Nextel Models.
    Nov 12, 2006 | Nextel i860
    Cell Phones Logo
    114 people viewed this question
    Top Nextel Cell Phones Experts
    Rommel Balcita
    Computer Repairing
    Computer Repairing
    ray gallant
    Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
