Question about Microsoft Computers & Internet
How do I expand margins of a table, so that on a single page I can create two columns wider than three inches, and four rows taller than two and a quarter inches?
  • 40 Answers
Try to setup first your paper page margin and then try to setup your table margin
Posted on Oct 07, 2010
How can I create a bulleted two column list within a resume document?
This requires you to create a table. Look for a Table menu or menu item in the Format menu. You'll need to tell it you want two columns and five rows in the table. After you've inserted the items you can then highlight everything in the table and right click to choose bullets from bullets and numbering from the format option.
Oct 04, 2015 | Computers & Internet
Tip
Deleting Rows & Columns from the table
You can also remove columns or rows from the table. Once a row or column is deleted, it can be undeleted by using Undo command. You can delete the columns or rows or cells by using one of the following ways.
By Table Menu
To delete a row or column by Table menu, follow these steps.
  • Place the insertion point in the column or row that is to be deleted.
  • Click Table menu and then select "Delete" from Table menu, a submenu of Delete is displayed.
  • Select Columns or Rows or Cells command to delete the selected element (column or row or cell) from the table.
By Popup Menu
To delete a row or column by popup menu, follow these steps.
  • Select the column's you want to delete.
  • Right click the mouse, a popup menu is displayed.
  • Select "Delete Columns" command, the selected columns will be deleted.
OR
  • Select "Delete Cells" command, "Delete Cells" dialog box is appeared.
  • Select "Delete entire row" to delete a row or select "Delete entire column" to delete a column etc. from the dialog box and click "Ok" button.
on Jan 29, 2010 | Computers & Internet
How to make a 7 row and a 7 coloum in a spreadsheet
Creating a table in Microsoft Excel 2007 allows you to work with that data independently of the rest of the worksheet. First you must define your table, though, which you can do either from scratch or from data already in the worksheet. The process is a simple one. Read on to learn how to define a table in Excel 2007
  • Start off by doing one of the following: Select the range of cells that you want to make into a table within your worksheet then proceed to Step 2 OR Start immediately with Step 2.
  • Click on the "Insert" tab at the top of the document.
  • Find the "Tables" group, then click on "Table." The "Create Table" dialog box will appear.
  • Type in a range for your table if you did not select a range in Step 1. If you did already select a range then that range will automatically appear in the dialog box.
  • Check the "My Table Has Headers" box if the data set you selected already contains the headers you want to use. If you don't check this box, the table will display default header names, which you can then go in and change.
  • Hit the "OK" button at the bottom of the Create Table dialog box to create your table.
  • Thanks for choosing Fixya............ Sandeep
    Mar 18, 2011 | Computers & Internet
    Hi. I made a web page in Frontpage. When I see it
    The tables are probably nested incorrectly as changing the aspect ratio is moving images. Keep in mind that each row must have the same number of columns, so to keep it simple, the base table has one column, and you need to create a nested table in every row that needs more than one column.
    At the very least, create a table for the whole page, and nested tables for each section. Use this template as a guideline:
    Default
    Header
    • The
    • menu
    • goes
    • here
    "Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum."
    Footer
    Mar 06, 2011 | Microsoft FrontPage 2003
    I can not draw a table in microsoft word
    hi ermelitacapa,
    To create a table in Microsoft Word please do the following:
    1. Go to the Table menu and select 'Insert Table'. The Insert Table window will open.
    2. Select the number of rows and columns you want in your table.
    3. Select the column width (up to 22 inches) or choose 'Auto' to have the column with adjust automatically, making the table extend across the width of the page.
    4. Select the AutoFormat button to select one of Word's pre-formatted table styles. The Table AutoFormat window opens.
    5. Click one of the styles in the Formats box in the upper left side of the window.
    6. Preview each format, after selecting it, in the Preview box in the upper right side of window.
    7. To customize a pre-selected format, select or de-select the borders, shading, font, color, heading rows, first column, last row and last column boxes.
    8. Select AutoFit, and Word will automatically fit the table to your page.
    (To manually change the width of a table or column after you have created it, use the mouse to place the pointer over the vertical line you want to move. When the pointer turns into a double-headed arrow, drag the line to the position you want it in the table.)'
    I hope this helps!
    ** If you find this information helpful please leave feedback to help us help others **
    Feb 24, 2011 | Microsoft Windows 7 Home Premium 64BIT...
    Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
    I assume this error is occuring in Microsoft Word.
    1. Create a new document, with a full page of the label you are having trouble printing.
    2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
    3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
    4. Click the Fix button to have Word change the margins
      to match your printer. You should now see the Margins dialog with the new margin settings.
    5. Click OK.
    One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
    If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
    1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
    2. Select the entire table of labels ([Ctrl]+[A]).
    3. Right-click the table, and select Table Properties.
    4. Click the Text wrapping "Around" option, then the Positioning button.
    5. Change the Horizontal position to Center, Relative to Page.
      Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
    6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
    With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
    Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
    Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
    Excel formula
    I'm assuming you'd like to assign a numerical value to cardinal references (1st, 2nd, 3rd, 4th, etc.).
    Best way to do this is to create a quick lookup table on a separate sheet of the same .xls document. Down at the bottom of the page, click on Sheet2 and create a quick table where column A has 1st, 2nd, 3rd, etc. and column B has your values.
    Now click back to Sheet1 where your data is and in A2 put this formula:
    =VLookup(A1, Sheet2!$A$1:$B$x, 2, FALSE)
    Note: replace the lower case x in the formula above with the number of the last row of data in your lookup table on Sheet2.
    You can copy and paste this formula down the column to calculate your other values.
    Hope that helps!
    Terry
    Aug 30, 2008 | Microsoft Excel for PC
    Flex Grid
    The most common multidimensional array, the two dimensional array table, is best presented to your users in row and column format. The grid control offers a convenient way for you to display table data to your users. The users can navigate the table's values using scrollbars. Therefore, the grid control does not have to be as large as the table, because the grid control automatically displays scrollbars.
    To add the flex grid control to your toolbox, select project and components. Add the flex grid control:
    lesson97-1.jpg Once it is added, you will see the yellow flex grid control in your toolbox:
    lesson97-2.jpg When you place the grid control on your form, you will have to resize it before the control takes on a tabular appearance. As you expand the size of the control, it does not look to much like a table. The problem is that the table's default number of rows and columns are two. To fix this problem, you must configure the rows and columns in the properties window:
    lesson97-3.jpg lesson97-4.jpg lesson97-5.jpg The grid control supports fixed rows and columns. These refer to rows and columns in a grid control that do not scroll when the user clicks the scrollbars. The fixed rows and columns provides labels that describe the data. The fixed rows and columns are often called row and column headers.
    lesson97-6.jpg When working with the grid control, much code is needed to provide the grid with functionality. Call statements are used to break the code required by the grid control into smaller, more manageable procedures. This is referred to as modular programming (which refers to the practice of placing code with a single purpose in a general subroutine procedure and then calling the code from a second procedure.)
    Here is the code for the form load procedure (this example is based on the computer disk example used in the last lesson)
    Private Sub Form_Load()
    Call SizeCells
    Call CenterCells
    grdGrid.Row = 0
    grdGrid.Col = 1
    grdGrid.Text = "Single Sided; Low Density "
    grdGrid.Col = 2
    grdGrid.Text = "Double Sided; Low Density"
    grdGrid.Col = 3
    grdGrid.Text = "Singled Sided; High Density"
    grdGrid.Col = 4
    grdGrid.Text = "Double Sided; High Density"
    grdGrid.Row = 1
    grdGrid.Col = 0
    grdGrid.Text = "3 1/2 inch"
    grdGrid.Col = 1
    grdGrid.Text = "$2.30"
    grdGrid.Col = 2
    grdGrid.Text = "$2.75"
    grdGrid.Col = 3
    grdGrid.Text = "$3.20"
    grdGrid.Col = 4
    grdGrid.Text = "$3.50"
    grdGrid.Row = 2
    grdGrid.Col = 0
    grdGrid.Text = "5 1/4 inch"
    grdGrid.Col = 1
    grdGrid.Text = "$1.75"
    grdGrid.Col = 2
    grdGrid.Text = "$2.10"
    grdGrid.Col = 3
    grdGrid.Text = "$2.60"
    grdGrid.Col = 4
    grdGrid.Text = "$2.95"
    End Sub
    Notice how the form load procedure is used to populate the cells in the grid control. To control cell size and cell alignment, two smaller procedures are created and each procedure is called by the form load procedure.
    Private Sub SizeCells()
    Dim intColumn As Integer
    grdGrid.ColWidth(0) = 1100
    For intColumn = 1 To 4
    grdGrid.ColWidth(intColumn) = 2200
    Next intColumn
    End Sub
    Private Sub CenterCells()
    grdGrid.ColAlignment(intColumn) = flexAlignCenterCenter
    Next intColumn
    End Sub
    Notice that the size and alignment procedures are only applied to columns 1 through 4. Column 0, which is a fixed column reserved for labels, is not formatted using either of the above two procedures.
    Here is the final result:
    Mar 26, 2008 | Computers & Internet
    How do you print divider tabs
    Depends on the size of your tabs...
    In Microsoft Word:
    Pull down the tools menu and select "Letters and Mailings" and then choose "Envelopes and Labels", choose the labels tab, and select "Avery 5836 - Divider -Mtg. Creator" or manually set a height of 0.5" and a width of 1.75".
    In any Word Processing Application:
    Make a table 10x1, set the row height to 0.5", and then set every other column width to 1.75" and 0.5" respectively with a 0.5" left and right margin, 1.0" bottom margin, and a 2.0" top margin. Add rows until you fill the page.
    Hope this was helpful and remember to vote...Thanks
    Dec 10, 2007 | HP LaserJet 2200D Printer
    Formula required
    at first select the 1st page data and select data-subtotal from the upper menu list.
    then enter the formula as =sum(1stpageSubTotal,2ndpageSubTotal,3rdpageSubTotal) then Press Enter.
    If not solved pls get me that data as to reference.
    thanks
    Dec 04, 2007 | Microsoft Excel for PC
    Computers & Internet Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
