Question about Sony VAIO PCV-MXS10 PC Desktop
My computer was getting pretty outdated, bought a new one, put my sony vaio pcv-mxs10 in the basement bar area and was going to just put in all cd's for music, I hooked up bigger speakers and all I got was static and played with the volume and then nothing - no sound at all, hooked back up original speakers and so forth played with the settings, even reinsalled recovery discs, the recovery did help, but if I just tweek the volume it blanks out. Question: Did I burn up my sound card by playing with the volume level when I had static?
  • Jim Culkin
    Jim Culkin Sep 12, 2012
    Sorry, forgot about this being on here. I replaced the sound card, found that as i originally hooked up big speakers, it did blow my sound card and problem solved.
  • 1,179 Answers
Nice
Posted on Sep 12, 2012
  • 5 Answers
SOURCE: PCV-RX463DS Sony Vaio SoundMAX Drivers
Try updating your proccesor, as if it is to small it might not be able to keep up with your new drivers. Good luck. -Thunderstar
Posted on Aug 12, 2007
Postalsusie
  • 40 Answers
SOURCE: Lost recovery dist for sony vaio pcv-rx500
I had an RX540 and I can tell you absolutely that you have NO options other than hopefully finding it in the classifieds. Sony is rigid about not only programs but also hardware that originally came with it.
You didnt mention you were having any problems right now so I assume all is up and running well? If so, I recommend 'ACRONIS TRUE IMAGE' its a back up program of my choice that lets you back up the entire operating system or just programs and you can back it up by making restore disk sets or simply cloning the whole drive to another drive. There are other programs that do this but I have tried a few and many times when you back up programs they will restore ok but then ask you for serial numbers. ACRONIS has only done that with one program that I have seen.
So simply..
search for a program that auto-copies all your serial numbers OR mark them down yourself and make some restore discs using Acronis or something similar.
I would also suggest cleaning any old files etc off your drive and running a scandisk and defrag before you do the back ups.(for good quality and speed)
When you back up.. back up the entire operating system AND all the programs.
If you only select operating system, all you will have is windoze.
In the future you can totally foul your windoze and simply boot to the Acronis recovery cd and the back ups ON CD and it will restore your computer.
Or.. do what I do. Once you have everything perfect, simply clone the entire drive to another drive and if it ever messes up just swap out the hard drive like changing a light bulb.*s* (always save your serials.)
By the way, a hard drive needs to be about 1/3 empty to work well and fast because there are windows memory and swap file issues. So free up some space for good performance ok ?
I hope this was helpful. good luck.*s*
Posted on Oct 26, 2008
gymowner
  • 679 Answers
SOURCE: NO SYSTEM RECOVERY IS WORKING on my Sony PCV-RS530G Windows XP
First get the trogen,malware or virus out, it is more than likelly causing the problem. Make sure you have a good virus program, I had one similar and most virus programs won't take it out or even show some of the latest bugs. Tech support is a waste of time for the most part, was your restore turned off?, Boot into safe mode, and run a spybot search and destroy, and AVG- free virus program that you can get on their site and download the program perhaps with another machine. Otherwise there are "DOS" commands that you can try, it could be the MBR, a corrupted file,or many other things. But if it happened suddenlly, chances are some kind of bug got in, you also are going to need a bootable Operating System Disk if this stuff dosen't work. good luck
Posted on Dec 15, 2008
  • 20 Answers
SOURCE: Sony VAIO PCV-RX500 Cant get recovery cds to work
since she formatted the hard drive there is no drivers for your cd rom to work
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Posted on Aug 21, 2009
  • 4 Answers
SOURCE: i have a sony vaio pcv-w1 desktop computer,is
no there is no way to recover it back if you diddnt did the recovery disk when you bought your computer.
Posted on Jan 26, 2010
Is there a current motherboard that will fit in a Sony Vaio pcv-RZ22g case to replace an old Asus P4S533 motherboard?
Desktop computer cases have mountings that suit the majority of motherboards.
You most like need a new switch mode power supply as the existion one won't have the correct power connectors and won't supply enough power.
Jan 22, 2013 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Disk boot failure.insert system disk. Message that appear a boot up
first of all check in your BIOS whether your motherboard is detecting your hard drive or not.
If yes try installing window.
If not it means your hard drive is not detected , Open the case and check hard drive data cable is connected properly or not, and hard drive is getting proper power supply.
you can try changing hard drive data cable and power connector from.
If still you are facing the same problem that means your hard drive gone bad.
Jun 15, 2011 | Sony VAIO PCV-MXS10 PC Desktop
I have a sony vaio pcv-rs420. well it wont boot or nothing. it turns on but thats it . i called sony support and they said they don't issue that disk anymore. the recovery disk. they want to charge me $$$$...
I am asuming you have a video signal but your operating system is corrupt. You mention you dont have and cannot get the recovery disk. If you dont want to spring for a new operating system go get a free one like Ubuntu 10.10 LTS ... Of course this means that you will have to have access to another computer that can download the ISO image and burn it to a CD. Good luck.
Nov 14, 2010 | Sony VAIO Digital Studio PCV-RS420 PC...
I need a Recovery Disk for the Sony VAIO PCV-W5100G Desktop Computer.
1. If you don't have a Recovery Disk for your system, then you should contact the manufacturer to supply any additional recovery disk! (http://esupport.sony.com/)
2. You can also check this article for further help :
http://www.tomshardware.com/forum/141527-32-sony-vaio-desktop-recovery-harddisk-failure
please rate this advice if it helps...tc! :)
Jan 13, 2010 | Sony VAIO PCV-W510G PC Desktop
I have a Sony Vaio desktop with XP. My DVD-CD
Have you tried burning a CD in the new drive? Because the drive is a DVD it will always be recognised as a DVD, but should work perfectly well with CDs both playing and recording.
Nov 07, 2009 | Sony VAIO Digital Studio PCV-RS220 PC...
I have a PCV RX 572 VAIO used computer at home. I
Yes this can all be done but it will cost you twice the cost of a new laptop.
Sep 09, 2009 | Sony Vaio PCVRX99IV PC Desktop
VAIO PCV-W510G Keyboar & mouse wont work
Hi torr3s_t,
Here is a web site where you can download your computers manual: http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVW510Ga . I would copy and paste the web site.
Here is Sony's support Number for computers: 239-768-7545 Monday- Saturday 11:00 AM-8:00 PM ET
Hope this helps,
GaWebSpinner
Jun 04, 2009 | Sony VAIO PCV-W510G PC Desktop
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
Nov 05, 2008 | Sony VAIO PCV-RX500 PC Desktop
Sony VAIO PCV-MXS10 PC Desktop Logo
59 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
