Question about Zoom H4 Handy Recorder
Hello. I have a problem with my ZOOM H4 recorder. When I try to turn it on (using ZOOM adaptor) it shows the the battery is low (but batteries aren't included) and tells me to turn it off. Also, when its turned off and the adoptor is plugged in, it shows the USB menu (connect to pc, etc.) but the USB isn't plugged in. Please help!
I have exact same problem, I got it to work temporarily by turning unit on then connecting AC adaptor into unit, it forced it to run, I formatted card and it worked for an hour now back to same old problem, I'll keep you informed. I believe it's faulty switch. help me if you can.
Posted on Feb 19, 2011
  • outerrealm13 Mar 16, 2011
    I found that using another power supply did the trick. One theory is that your line voltage in your building varies enough to make the unit unhappy, and another power supply may give more voltage or current sufficient for power up. The Zoom power supply is only rated at 50ma, which is VERY low for a 9v supply. I suspect that under some circumstances the zoom requires more power than the Zoom power supply can give. I recommend trying at least a 300ma one. I keep power supplies plugged in at various spots in my studio area so as not to have to plug and unplug them as I move from instrument to instrument.
  • bohneforsber Mar 17, 2011
    are the different power supplies made by different suppliers?
Hi! I placed a bid on Ebay, on a used Zoom H4 and didn't read the fine print! I now notice that the seller says that the condition is good, but the battery operation doesn't work - it only works with the...
Usually the problem will be with the battery contacts. Often corrosion due to leaving batteries in too long or the spring contacts, don't. Another harder thing is the adapter connector often has a spring blade that contacts the center pin when adapter is unplugged to switch to battery. These get bent and are a chronic problem for devices that use either adapter or battery.
Apr 13, 2011 | Zoom H4 Handy Recorder
My Zoom h4 has been struggling for a couple months now. Most of the time I get either an error message concerning the card or saying the card is full. Even when the card has been reformatted both on my pc...
Make sure the batteries are good... some people try to use re-chargeable batteries and because of their lower voltage they cause problems. First thing is to try new batteries.
Feb 12, 2011 | Zoom H4 Handy Recorder
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
My Zoom H4 will no longer run with batteries. If I use AC adaptor it works fine but I get nothing on battery power
Probably the connector where you plug the AC adapter into has a switch contact that disconnects the battery when external adapter is used and it has gotten bent so when the adapter is not plugged in, it no longer makes contact to the battery power. This is pretty common for devices that use both battery and adapters.
Aug 23, 2009 | Zoom H4 Handy Recorder
H4 zoom battery operation
try resoldering the circuit board where the power socket is ... as there is a switch on the socket that disconnects the batterys
Jul 02, 2009 | Zoom H4 Handy Recorder
Zoom H4 recorded data disappearing
I have a H4 but not that problem. Have you tried recording when the H4 is charged? My guess is when low on battery, the H4 doesn't record.
Sep 02, 2017 | Zoom H4 Handy Recorder
Zoom H4 does not power up on battery power.
Probably two years too late, but I recently got a used H4 and it was having this same issue. Upon reading the documentation, it seemed as though it required a specific type of AA batteries. If you update the firmware (mine was 1.3) to the latest version (currently 2.4), you can toggle the battery type under the menu (most likely alkaline is what you want). It also added lots of other great features!
Jun 02, 2009 | Zoom H4 Handy Recorder
Zoom H-4
Ask your dealer, the one you bought it from. They may suggest an easy fix or guide you best on how to get it repaired, or at the very least suggest a place near you to have it repaired. If your dealer doesn't know, ask any Zoom dealer for repair info. Meanwhile, I assume you've checked your battery compartment to make sure the terminal connections are not loose (and of course that you've tried new batteries - :) ). Also, check Menu>Battery to see if alkaline or nickel batteries is checked. Finally, try removing your SD card and re-inserting, (even re-formatting the card, perhaps, but trying merely re-inserting first). But make sure any songs/info on the card are backed up first, because you will lose info if re-formatting the card. (For that matter, you could try a new card.)
Sep 11, 2008 | Zoom H4 Handy Recorder
If you used the adapter to power it with batteries in, you may have blown it
Apr 01, 2008 | Zoom H4 Handy Recorder
Distortion with Zoom H4 as Audio I/O to computer
try using the power pack instead of batteries. Be sure to remove the batteries before using power pack, you can wreck the machine if you do not remove batteries. NEVER use the H4 on power pack while there is batteries inside.
Mar 31, 2008 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
232 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
