Question about Actiontec (GT704WG) Router
Found actiontec with nothing using mac need help with setting up wifi
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Use this link:
http://www.actiontec.com/support/product_details.php?pid=40
There you will find everything you need.
Posted on Oct 07, 2010
My cell phone WIFI is just blinking for 10 days now and not able to turn on
If phone is new it is still under warranty - replace it.
Nov 09, 2015 | Cell Phones
Forgot my verizon actiontec router password
wifi password or the password for logging into the router settings? If you do a factory reset on the router it will put all settings back to default settings, the default password can normally be found on a sticker on the side or bottom of router. it will say "WEP" or "WPA2 key". you factory reset the router by holding down a red button (inside of a hole) on the back of the router for 12+ seconds while its still powered on.
Jan 08, 2014 | Actiontec Computers & Internet
Need to set up wifi security
Find your modem on this page: http://www.pcwintech.com/screenshots-actiontec-routersmodems
..once you've found your modem you can type "192.168.1.1" into your internet browser. There will be an option for wireless once you're in there.
Apr 29, 2011 | Actiontec (GT701) Modem
Have actiontec dsl modem router combo i believe because with our contract w/qwest we have wifi connection they gave us 2 actiontec wifi usb adapters but xbox360 doesnt reconize the adapter, i have xp media...
You have two options that I know will work.
Run a Ethernet cable from you router or switch to the XBOX and just plug it in. Ethernet is good for 325 feet but it is best if you keep it below 300 feet. Here is a good place to shop for this type of stuff: www.newegg.com
You can also get an WIFI adapter that is 100% compatible with your XBOX. Actiontec is the worst of the worst. Here is an real Microsoft XBOX adapter: http://www.amazon.com/Xbox-360-Wireless-Network-Adapter-Networks/dp/B000B6MLV4
FYI: Customer support at any ISP or cable company are non-technical people that have no knowledge of how things work. If they did they would be answering phones all day. I find it hard to believe that they would know what works on an XBOX and they are fools for recommending Actiontec products.
Jan 16, 2011 | Computers & Internet
I need a wep code for an Actiontec GT704-WG. Trying to setup internet connection for wii and the code that is on on the modem does not work .
here is a setup guide to help you get the wep key. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
May 15, 2010 | Actiontec GT704WG Wireless Router...
Unable to connect nintendo wifi gaming with Actiontec GT704WG help
you will need to setup your port fowarding in the router interface
Jul 17, 2009 | Actiontec GT704WG Wireless Router...
Trying to add ipod for wifi usage
Maybe this is what you are looking for.
http://support.apple.com/kb/HT2031
Have a look especially at point 5.) of the WiFi settings.
If you have any more questions ot I misunderstood your problem, just come back here and leave a comment - I'm happy to help.
May 23, 2009 | Actiontec Computers & Internet
Actiontec (GT704WG) Router Logo
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
