Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker doesn't work
If i sign up for 19.95 will you help untill I fix the problem
  • 770 Answers
What is the problem you are having ???
Yes we will fix the problem but there is no way i can tell if you will get me as your tech
Posted on May 29, 2008
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
These will help.
Dec 23, 2012 | Refrigerators
Water dispensing into ice maker won't shut off
There should be a float or electronic water level sensor that will tell the water to shut off, if it has calcium from the water on it or the float is damaged it will keep sending water until manually shut off(pull the plug). I would look for a water level sensor of some sort and clean or replace it. If that doesn't work it could be a sticking water fill solonoid which you should then replace
Sep 06, 2012 | General Electric GSH22JSXSS Stainless...
I need the instruction manual for the deni ice crem maker model 5400
I've scanned the manual for the Deni 5400 as a PDF file. I posted it on here I have one and it still works.
If it doesn't show up, you can use this link to get the instructional manual PDF. I'll leave it there for a while.
If you appreciate this and like the Dropbox sharing service, you can sign up to get an extra 250MB of storage using my referral link
Sep 17, 2011 | Deni 5400 Scoop Factory 1.5 Quart Ice...
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
Ice maker doesn't make ice. It seems to not being able to rotate the ice tray to dump the ice.
this may be a bad heater in bottom of ice maker . if so replace the ice mker .. but do ck the tempts ..freezer must be 15 de or lower for ice maker to work properly .. hope this helps mm .. feed back pls ..
Jul 10, 2011 | LG LMX28988
Ice maker will not make ice
It sounds like you might have a bad fill valve. There are several reasons that an ice-maker doesn't get water. If the freezer isn't cold enough, the ice-maker thermostat will not allow it cycle. There are two different styles of ice-makers. Pull the white cover off of the ice-maker, if you see two gears the you have one of the earlier models. Turn the smaller of the two gears counterclockwise slowly until the gears start to turn by themselves. Now if you do not have the two gears under the cover, then you have a modular ice-maker. There are several holes in the brown plate. Each hole will have a letter beside it. Jumper between the T and H holes until the ice-maker starts to turn by itself ( you should hear a click if you'll listen closely). Now that you ave cycled the ice-maker, check and see if there is water in the ice tray. If you still have no water then change your fill valve. If you do have water then its usually cheaper to replace the actual ice-maker. Be sure to check the temp of the freezer, most ice-makers will not cycle above 10F degrees. Most ice-makers are around $130. Most valves are around $50. I hope this helps you solve the NO ICE situation. Thanks for using , please let me know how it goes, thanks mike
Jun 06, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
Model #ed5ftgxkq01 ice maker stopped working
Looks like your fridge is not very old. Common problem is a clog inside the ice maker. It's a pain to do, probably easyer to get it fixed unless you have a long time to wait for a service call or live in an area without service. Anyway clog is most likely about an inch from the in take line inside the ice maker.
Take out the ice maker or turn off the freezer untill it thaw's then use a tooth pick or THIN ice pick to push the clog through to the actual freezing tray, wash out the tray and re start the ice maker.
Hope this helps.......
Aug 01, 2010 | Whirlpool Refrigerators
Ice maker is not getting water supply but water dispenser works
the fill valve for the ice dispenser has gone bad there are two separate fill valves for the water dispencer and the ice maker
Sep 20, 2009 | Refrigerators
An apppliance company has installed three ice makers and none of the three have worked. they may drop ice once or twice in a 24 hour period. there is also frozen water in the ice bin. Can you tell me what...
you can make ice at30/31 degrees F but ice makers do not start until it is 0/4F clean all coils and if it has a condenser fan see if it works or you may be just low on freon thumbs up
Aug 12, 2009 | Refrigerators
GE Ice maker water flooding
Dear friend,
ngfam at you service! happy to assist!
Perhaps you should try service!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Aug 29, 2008 | Hotpoint HSS25GFP Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
32 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
