Question about Frigidaire Dryers
My dryer is making loud noise and after it gets warmed u it stops. I have replaced felt inside
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 07, 2010
There is a felt seal attached to inside of front panel on dryer. The drum sits and rolls on this. It has fallen off and now the drum rubs on front panel making very loud noises.
You need the make and model of the dryer. From that you can get the felt part number.
Here is a link to a site that sell these parts;
Dryer Felt Seal
Also, if the dryer is old, I suggest that you look at replacing the drum support wheels. The bearing wear out and make noise.
j
Jul 12, 2015 | Dryers
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 | Dryers
Frigidaire affinity front load dryer
You need an upper felt and a rear drum bearing. If you buy the felt make sure you get the special adhesive to install it. The squeal maybe part of this or it could be the rear drum bearing. You can learn how to replace the rear drum bearing here in the article I wrote. http://gomestic.com/do-it-yourself/how-to-replace-a-frigidaire-dryer-rear-drum-bearing/
Jan 29, 2014 | Dryers
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
My dryer started making a loud noise - Amana model alg443raw - then I opened the door and the felt seal and a metal piece were inside and wrapped around my clothes. I know what the felt seal is, but what...
heatman101
fsgfgf
Sep 25, 2010 | Amana ALG443RAW Gas Dryer
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
Will not turn on..
Hi trishis26,
If it was the motor you would still be able to hear it trying to start. The will make a loud hummmmm. Since it is doing nothing you most likely have a bad thermal fuse.
Other possible problems include the door switch, the start switch, the timer, the breaker in your home. If you need more help, just let me know and I will be happy to try to help you figure it out. Good luck.
Mike
Sep 29, 2008 | GE DBSR453EBWW Electric Dryer
Ge select electric dryer
it may be clogged on the inside of the machine not just the exhust tube.
Jan 10, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
