Question about Maytag Dryers
I have a performa dryer and it will not give out any heat. It is 4 years old.
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 07, 2010
I have a Maytag Performa PYE/G2300. It is 8 years old and is making a sound like when a landing gear is coming down on a plane. Any idea's
The most common problem on these units is the right rear roller that supports the back half of the drum. It usually will seize up because its located closest to the heating element/burner assy. The heat causes the bearing to expand. Hope this helps.
_MJ_
Dec 15, 2010 | Maytag Dryers
TL751 is two years old. Heating element burned
You did clean out the dryer before turning it back on?
May 10, 2010 | Asko TL751 Electric Dryer
My Maytag Performa won't run at all
I looked up your model. The blower wheel on these 31001317
causes the dryer to over heat. The fuse kit LA-1053 mounts here:e930c75.jpg
Apr 13, 2010 | Maytag PYE2300AY Electric Dryer
My Maytag Performa dryer just quit. About 7 years old. Better to get it fixed, or replace it?
you need to check the set of thermal fuses.you need to lift the lid on the dryer and look in the back on the left you find the heating element.there is a large thermal fuse right on top of it,then on the side of the can there is another one that is usually the one that goes bad.the part number is la-1053 you replace all three of them.but first thing you need to check for continuity on them. if they are good then check the continuity on the heating element.replace if needed
Feb 27, 2010 | Maytag Performa PAV2200
Maytag performa pav2200 dryer has stopped heating
heatman101
tust
Jan 24, 2010 | Maytag Performa PAV2200
Kenmore Gas Dryer is 7 years old. It will heat up
Replace the gas valve coils. Common problem after 3-4 years.
Jul 05, 2009 | Kenmore Dryers
Maytag performa dryer doesn't fully heat
A couple of suggestions. STOP, be sure the gas it turned off before disconnecting the line. Move it to an open area and check all venting. A good cleaning makes a huge difference. I believe your problem to be the heating coil is on it's way out, "works sometime". Write down the Make, Model, Seriel Number & Year of MFG...someone may ask for it..Check Your local appliance store for price & availablity Easy to replace on most model dryers.
When reattaching the gas line, be safe not to overtighten the coupler. A safe test for leaks is NOT a match... a drop or two of dishsoap around the fittings will bubble if it is not sealed. Good Luck
Jan 02, 2009 | Maytag Performa PAV3200
No heat from dryer.
Do not buy or use a maytag performa dryer model number pye2300ay at all. I fyou have one unplug it and take to the landfill or scrap yard. They are complete junk and nothing but a hassle. One problem after the other on this model no matter what you do. they are complete trash and a waste of your money.
Nov 24, 2008 | Maytag Performa PAV2200
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Dryers Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
