Question about HP PSC 1350 All-In-One Thermal Printer
Just got a new computer and do not know how to set printer up for printing
  • HP Master
  • 7,733 Answers
Insert the printer CD and start the installation and follow the steps.
Posted on Oct 07, 2010
I get a message that my HP 5500 is not connected to my new iMac but the printer says it is connected. How to solve?
The printer says that it is connected correctly to the router because the router is aware of it and has assigned to it an IP address on the network.
The computer on the other hand does not know that there is a printer. Not finding one (or not knowing where to look for it) the computer reports that the printer is offline.
You must install the printer drivers on the computer.
May 25, 2012 | Apple Computers & Internet
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
My daughter was messing with the printer. When I print anything now, the printer prints out a thick black line covering everything where the text should be. Is there a way to re-set the printer to get it...
Disconnect the printer from the computer momentarily. Allow to lay idle for a while, then reconnect to power on the computer. A new allignment instructions will be requested from computer on attempt to print with new settings.
Jan 29, 2011 | Dell 946 All-In-One InkJet Printer
HP Printer Deskjet 697C won't print color
Unfortunately when a inkjet printer is not used in a while the ink dries up... If I was you I would try a new color cartridge and see if that helps out. It is a fine balance with ink jet printers... you don't want to print so much because ink is expensive but you want to print enough to keep the heads and ink from drying out. Good Luck!!!
cdixon18
The Man Inside the Machine
May 11, 2009 | Office Equipment & Supplies
Cannot print from Word Perfect 11 or Quattro to Xerox Phaser 85
It is the print setting in WP. As I'm sure you know, Corel products like to take control of everything. If your document is configure to print to an HP printer, for example, it won't print to another printer unless you change it in the Print settings within the document.
Feb 05, 2009 | Xerox Phaser 8560DN Laser Printer
I can not print
Cannot print? What you mean? Cannot print from computer? Or basically the printer will not print.
If this is only a printer there is a self test so you can print without using the computer in that way you will know if it still works, if it prints good its on the settings on your computer.
If this is an all-in-one printer why not copy something. You will know if the printer is working fine.
Nov 10, 2008 | Lexmark Office Equipment & Supplies
Laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Oct 18, 2008 | HP LaserJet 2430dtn Printer
Removal of border on bottom and right side of 8X10 print of color slide.
well this could be caused by a couple of things that i know about.
1: there is a line of dirton the drum, which may need to be cleaned to clear it.
2: there is a shadow set up when it prints now.
May 30, 2008 | Epson RX620 All-In-One InkJet Photo...
Darker color printing
dear Friend pls check your print Quality in printer preference setting ,is it possible due to Hi density (print Resoluction)
other wise Check printer on other New computer with new Printer Drivers Installation
May 29, 2008 | HP LaserJet 2420dn Printer
Print size
Need to know what OS you are using - are you printing PCL or postscript. How are the computers connecting to the printer network or direct connection?
Nov 28, 2007 | OKI B4350 Laser Printer
HP PSC 1350 All-In-One Thermal Printer Logo
13 people viewed this question
Seeker5211
Seeker5211
