Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Connections I am having a problem hooking up my cd player to my mixer and amplifier, I can't get the connections right.
Need more info as to where you are trying to plug them into
Posted on Sep 27, 2008
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
How to hook power amp to mixer
The output of mixer connects to channel A or B of the separate amplifier and the output of the am connects to the speakers. Amp channels are listed as A and B or 1 and 2 instead of Left and Right because the manufacturer does not assume how you may wire your system. Please remember that compression, limiters and EQ device connect between the mixer and the amplifier with their prespective IN and OUT levels adjusted accordingly.
Apr 30, 2012 | Mackie 1604 Vlz3 16 Channel Mixer
Pioneer cdj-1000 mk2 sound issue
Diconnnect the player from the mixer, hook directly to your receiver or amplifier, now try it out, if nothing! replace the audio cords from the player to the receiver/amp, power up both units, hopefully this will work.
Mar 22, 2012 | Pioneer CDJ-1000 CD Player
Cant Get sound from CD Player when Connected to Phonic Live Mixer
REPLACE THE RCA CABLE COULD BE THE GROUND MAY HAVE GONE BAD....CHECK THAT THE AMP HAS A GOOD GROUND TO THE CAR WITH A METER MAKE SURE IF IT HAS A SWITCH FOR LOW IMP OR HIGH IMP IT IS IN THE RIGHT POSITION GOOD LUCK
Feb 14, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Pre Amp Set up
Get the right cables and plug them in. Pre-amp to mixer to amp. Radio Shack is a good place to buy the wires with proper ends on them.
Jul 22, 2008 | Audio Players & Recorders
Connecting cd player to mixer
This should work. I use a similar setup for break music at small gigs. I would check the cable and the output of the unit itself again. .
Feb 21, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Low Audio
You need to connect the turntable to a PHONO input on your amplifier. Not all amplifiers have a phono input, if yours doesn't you need to get an RIAA pre-amp to plug your deck into & this connects to your amplifier.
This is because although the audio outputs on the turntable look the same as all the other components, they are very different. The signal has not been amplified up to line-level like tuners, CD players, tape decks, etc. You need to get this thin, weak signal boosted.
Your 3 options are:
* Connect directly to the PHONO input on your amplifier if you have one. If you don't:
* Connect deck to a RIAA amp (also called a phono stage) then connect to any input EXCEPT phono on your amplifier
*Connect the deck to a DJ mixer then hook the mixer up to any input on the amp EXCEPT phono.
Dec 23, 2007 | Technics SL-1200M3D Turntable
Numark cd mix 2
Well, it's not that hard to set up. What do you need help with? If you want to know how to connect:
1) The CD units go into the back of the mixer - in the CD / LINE INPUT - Left side on CD / LINE INPUT 1 and Right side to CD / LINE INPUT 2
The output of the mixer - MASTER OUT - goes to the INPUT of your stereo, amplifier, or receiver's LINE INPUT connection.
That's it. Press PLAY on your CD players, and raise the faders/volumes, and your all ready to go.
- TWEAK AV LAB
Nov 30, 2007 | Numark Fusion 494 Complete DJ Package
I'm have'n a problem
You should be connecting this product to a dj mixer because this unit has no internal mixer.To accomplish this you should connect the two outputs lines for channel 1 from this cd player to the two input lines on channel 1 of your mixer and the same for channel two, connect channel two from your cd player to the channel two input on your mixer and then hook your mixer to a amplifier, then amplifier to speakers. D.J Fire in Louisiana***
Oct 15, 2007 | American Audio DCD-PRO310
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
