Question about Maytag Atlantis MDE7400AY Electric Dryer
Drum has loose sounding rattle and clunk when rotating. I want to take off top to look at problem and order part to fix.
  • 171 Answers
This is a maytag and it comes apart by taking out the screws in the front at the bottom.Not under the unit but there is probably a bit of a lip or a ledge and it has the screws at the bottom of it.Once you get it open you will prob ably find that one of the wheels is worn out that the drum runs on and needs replacing.
Make sure to get the make and model numbers so that they will be able to give you the right wheel. It is a go od idea to replace all the wheels (3 or 4) because the older ones will wear much faster once you replace just the one so save yourself the aggrivation and spend a couple more bucks to do the whole set and they will be good for years to come.
Posted on Oct 07, 2010
  • SkintKunckle May 26, 2011
    Just had the same problem of a rattling sound comming from the drum. I ended up taking the front off to excess the bolts on the fins. After slightly loosening one of the fins two coins fell out. Problem solved.
Sdg109wf when running it like rattling sound coming out. what do i\I have to do?
You may have to find a way to identify the location of the sound; type of sound..metal on metal, like something is loose?
The only thing I know that rattles in a dryer is if something got into the baffles/the wings on the inside of the drum.
If this is the case you have to open the top of the drum and unscrew the one baffle that that has something loose in it.
Oct 18, 2013 | Dryers
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
The dryer made a clunk sound and the tumbler stop rotating
Sounds like you belt has either broke or came off. If you were rotating the drum by hand in the counter clockwise direction when it clunked, there is a pulley kit to fix that problem. If it was just running when it clunked the belt probably just broke. Hope that helps
Aug 29, 2011 | Samsung DV448AEE Electric Dryer
Rattles when drying
I need more details but typically a dryer will make a rhythmic rattling noise when loose change and other small metallic objects as well as buttons become trapped in the tumbler impellers (those wing shaped things in dryers).
Loosen and remove the top of your dryer.
Rotate your drum, taking care not to rotate it the wrong way. The right direction of rotation will produce friction to the belt, the wrong direction will cause slack on the belt on one side or the other of the drum.
Rotate the drum until the back side of the impeller is directly on top with the outer screws facing you at the top of the dryer. Remove the screws and pull out the impeller and you will find your noise makers. Do this with the remaining impellers and reinstall.
Mar 05, 2010 | Dryers
Washer has worked great for almost a year but now all the loads seem to be unbalanced. It doesn't matter if they are large, small or on any particular cycle, they all sound unbalanced and shake my house...
The motion dampers that control the outer tub's movement within the cabinet may be loose or damaged. Lift up on the inner drum when the machine is off to see if the drum moves with a 'clunking' sound which would indicate a bad drum shaft bearing (not a cheap fix). If it seems ok, remove the top and back panels to check the action of the dampers when the outer drum is shaken. Hope this helps!
Jan 07, 2010 | LG WM2487H Front Load Washer
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 80 Series loud rattling noise
Its called a Drum Support. Purchase at any appliance parts supply store or online from Sears or Whirlpool.
Part# 3397588 or 349241T (Pk of 2)
Jun 08, 2009 | Kenmore 63942 Dryer
Sloppy play in laundry drum
it sounds like the main drum bearing has gone you should call a local engineer to confirm good luck
Mar 09, 2008 | Kenmore 24032\24036 Top Load Washer
Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Dec 11, 2006 | Asko T781 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
364 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
