Question about Dometic RM2852 Refrigerator
RM 2852 Le réfrigérateur gèle. Ajustement de la sonde ?
4 Suggested Answers
  • 46 Answers
SOURCE: 2002 RM 2852, the refrigerator (lower section) will not work its warm inside, but the freezer (upper section) works fine, it will freeze water bottle to hard ice. All fuses are good. Please help!!
cooling unit is bad my friend there is a temporary fix but in my opinion not worth your time take the unit out and flip the refer upside down this sometimes dislodges the blockage in the cooling unit all a rv fridge is is amonia and salt if not used all the time the salt crystalizes in the orfice and blocks the unit a rebult cooling unit 550 about and labor 4 hours at your dealers rate a new fridge about 1500 installed
my shop 360 for labor 550 about for unit 910
I ALLWAYS RECOMEND REPLACING THE FRIDE COMPLETLTY
you get all new electronics and a new box
Posted on Aug 01, 2009
  • 183 Answers
SOURCE: Refrigerator for lp-gas and electri
SOLENOID VALVE Check the solenoid coil with a properly calibrated ohm meter. Remove the connector from the solenoid and measure the resistance across the terminals. The proper reading would be 49 ohms with tolerance range of ten percent. . . Next, hook up a manometer at the test port. Then check for DC volts at gas valve terminals while the unit is in trial-for-ianition. If DC volts are present and pressure is low, replace the valve. If DC volts are not present at the valve while the unit is in trial-for-ianition, verify that the wire at Plug 3, Terminal 2 on lower circuit board have DC volts v (9V or more)
IGNITER First verify proper voltage at the positive (+) and ground (-) terminals of the ignitor. The reading should be within one volt of incoming voltage at the main terminal block during trial-for-inanition Next, remove high voltage cable from igniter. The igniter should produce a sparking sound, during trial-for-inanition. If not, replace the igniter. The igniter installed on the refrigerators as original equipment is part number 2931132019 (RV Gas Model 679). This igniter is rated 50 MA. This igniter may also be used on any other model
Hope this helped
Appliance Wiz
Inanition: Proofing for ignition
Posted on Dec 27, 2010
  • 5370 Answers
SOURCE: refrigerator is running on LP-gas
As per the problem, its indicating towards bad thermister, it has to be replaced.----- The thermister is the part That controls the temperature.---- To test the thermistor follow this procedure :--- Disconnect the thermistor harness from the P2, 2-pin terminal on the lower circuit board. Place the thermistor in a glass of ice water (more ice than water), approximately 33° F to 35° F. Wait 8 to 10 minutes. You should get a reading of approximately 8,000 to 10,000 ohms. Always test from the wire side as shown with the meter as not to create a connection problem at the P2 connector. -------- There is a service manual available for your dometic rm-2652 refrigerator. Click the link below:-- http://www.fourwheelcampers.com/NewDometicRefrigeratorManual.pdf --------- On page number 11 is mentioned about thermistor.---Be sure that it just didn't get knocked off the fin where it attaches in the fridge. If it tests bad then it is about a $30 part depending on where you buy it and it takes about an hour to replace. Also be sure it has a good connection on the control board.
all tests are provided in service manual.-------
Also click this link for more details:--- http://technoanswers.blogspot.com/2011/07/dometic-fridge-freezing-in-refrigerator.html ---------- This should help.thanks.Helpmech.
Posted on Jul 08, 2011
Mon tapis roulant sportcraft tx390 ,a commencer a sentir le brule 3 jour apret que jais du ajuste mon tapis car il avais tendense a bouge sur la droite et frote donc jais fait un ajustement et cest...
bonjour, quand je fais partir mon tapis roulant il fonctionne pendant quelques seconde, ensuite le chiffre ( 3 ) s`affiche dans le coin gauche et il cesse de fonctionner, pourriez-vous m`aider? Merci
Apr 12, 2012 | Cars & Trucks
J'ai un probleme dans pc hp compac perisario c700 systeme 7 je trouve pas driver du touch pad
Regardez sous l'ordinateur portable pour le numéro de type précis et trouvez ce numéro de type ici:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?...1957&prodSeriesId=3466274
Vous trouverez le conducteur de touchpad sur le site Web précédemment mentionné. Téléchargez le conducteur et l'installez.
Sep 19, 2011 | Computers & Internet
Ne trouve pas le pilote du dvd ram gt 31n le mien ne fonctionne plus
QUESTION: "can not find the driver dvd ram gt 31n mine no longer works"
Salut.
Il n'est pas clair ce que vous entendez par "DVD-RAM 31n GT." J'ai fait des recherches de ce numéro de modèle "GT 31n", sans succès. Je vais donc supposer que c'est le numéro de modèle du lecteur de disque optique interne (DVD-RAM) de votre ordinateur.
Vous ne dites pas quel système d'exploitation que vous utilisez. Vous avez également choisi de ne pas donner toutes les informations concernant votre ordinateur ou de ses spécifications. Ces aurait pu avoir été des éléments d'information utiles.
Presque chaque système d'exploitation informatique, en particulier les courants, ne nécessite aucun pilote supplémentaire pour les lecteurs optiques comme celle du lecteur DVD-RAM. Les pilotes pour fonctionner presque chaque lecteur optique sont déjà intégrés dans le système d'exploitation.
Le seul logiciel que vous pouvez télécharger pour ce lecteur optique est Firmware. Firmware améliore et renforce les spécifications de performance, mais on peut rarement réparer les défauts ou restaurer un disque optique non-fonctionnement d'une fonctionnalité normale avec Firmware.
Vérifiez l'étiquette pour le fabricant du lecteur. Il est susceptible d'avoir été fabriqué par l'une des entreprises connues pour ce produit (LG, Sony, Hitachi, Samsung, etc.) Allez sur le site Support et Téléchargements de cette entreprise et vérifiez les mises à jour du Firmware associés à ce lecteur optique et de votre système d'exploitation.
Je suis presque certain que peu importe où vous regardez, vous ne trouverez pas de pilotes pour ce périphérique.
Si l'appareil ne fonctionne pas il pourrait être un problème de Jumper Settings. Regardez à l'arrière du lecteur pour voir le Jumper Pins et le Jumper. Regardez sur l'étiquette pour voir un diagramme des paramètres différents pôles.
Si il est toujours défectueux, essayez de le connecter avec un autre câble IDE, et essayez de nettoyer la lentille laser avec un Nettoyeur de CD DVD Lens.
Si il est lente, c'est peut être un problème avec l'ordinateur. Certains systèmes d'exploitation va automatiquement ralentir un lecteur optique à une faible vitesse de base après il a démontré un certain nombre d'erreurs de lecture.
Aussi essayez de vérifier et modifier les paramètres (SATA /) IDE dans le BIOS.
Enfin, le lecteur peut aussi être défectueux et peut-être a besoin d'être remplacé.
J'espère que cela aide.
Si cette réponse va certaine manière à aider à résoudre votre requête, un problème ou de défaut, s'il vous plaît prendre le temps de l'évaluer.
Cela permet aux fournisseurs de solutions, comme moi, mieux comprendre les besoins et le point de vue des questionneurs, comme vous, et nous guide dans l'exploration des meilleures façons de fournir les réponses les plus complets de qualité, utiles et de haute et de solutions que nous pouvons.
Si vous avez besoin d'aide, s'il vous plaît n'hésitez pas à poster une autre question ou ajouter un commentaire à cette question.
Merci pour avoir utilisé FixYa.
Sep 15, 2011 | Computers & Internet
Le son des hauts parleurs ne fonctionnent plus etc,est un modele de logitech ls21
Bonjour bouscotte
Je les testerais d' abord sur un autre pc pour voir si le mal vient bien des HP . Si oui , ne connaissant le modèle par coeur , je suppose qu' il y a un sub . Vérifie s' il n' y a pas un fusible de sécurité et vois s' il est toujours intact . Les connections sont à contrôler .
Après cela , je ne vois qu' une panne de l' ampli dans le sub mais c' est peu probable . Je pense plutôt à un disfonctionnement de la carte son ou bien le son est coupé accidentellement . Clique sur l' icone du hp dans la barre des tâches en bas à droite de l' écran et vois ce qui se passe dans le mélangeur . Si tout est normal à cet endroit , il ne reste plus que la carte son . Vérifie le pilote via le gestionnaire des périphériques . Remplacer la carte son , si nécessaire , ne coûte pas cher .
Bon courage ,
fanaudi .
Mar 25, 2011 | Audio Players & Recorders
Comment fait on pour relacher la lumiere du changement d'huile qui allume p¸ontiac grand am 2002
Réponse
Je ne pense pas que la «pédale de gaz façon« travaille sur cette année. La bonne façon de le faire:
Tournez la clé sur ON - ne démarre pas. Appuyez sur le bouton RESET dans la boîte de fusibles du côté conducteur. Changement d'huile de lumière sur tableau de bord doit commencer à clignoter. Maintenant Maintenir enfoncé le bouton RESET jusqu'à ce que la lumière de changement d'huile s'éteint et vous ici 3-carillons. Bonne chance et merci pour votre question et j'espère que mes suggestions aider. N'oubliez pas de taux de moi.
burdfrenzy
Visitez ma Boutique eBay! http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Jan 07, 2011 | Pontiac Grand Am Cars & Trucks
Samsung bloqué par opérateur
Qu'est-ce qu'un code PUK? Un code PUK (Pin Unlock Key) est nécessaire lorsque vous entrez un code PIN erroné 3 fois. Après avoir entré le code PIN erroné 3 fois, la carte sera verrouillé et vous devez obtenir un code PUK auprès de votre prestataire de service pour le déverrouiller. Que devez-vous faire si votre téléphone dit Entrez le code PUK Code? Vous pouvez recevoir des appels de code PUK de votre de fournisseur, soit en vous connectant à votre compte sans fil à mon compte; visitant notre Chat d'assistance technique ou en téléphonant au service à la clientèle. Une fois votre code PUK a été reçu, il sera nécessaire d'entrer dans votre téléphone pour définir un nouveau code PIN.
Si le mauvais code PUK est entré 10 fois d'affilée, la carte SIM devient invalide (verrouillées en permanence) et vous devrez acheter une nouvelle carte SIM. Le téléphone affichera «PUK bloqué opérateur d'appel» ci-dessous. Si votre périphérique a besoin d'PUK 2 s'il vous plaît appelez à la clientèle: soins. Pour obtenir votre code PUK, en log myWireless compte et suivez les étapes 1. Sélectionnez Téléphone & Device 2. Sélectionnez le lien Débloquer la carte SIM 3. Suivez les instructions sur le pop-up page Comment débloquer votre carte SIM Vous aurez besoin de votre téléphone dans la main afin de débloquer votre carte SIM. 1. Tout d'abord, entrez le code PUK chiffres 8, puis appuyez sur OK / Oui:. Remarque: Certains utilisateurs de téléphones Motorola devrez entrer ** 05 * si "Entrez le code PUK» n'est pas déjà affichée. Après avoir entré ** 05 *, puis entrez le code PUK chiffres 8 et appuyez sur OK. 2. Choisissez un nouveau code PIN, puis appuyez sur OK / Oui. 3. Re-entrer le code PIN, puis appuyez sur OK / Oui. 4. Si les codes ont été conclus avec succès, le téléphone est prêt à l'emploi.
J'espère que cela vous aide, ecuse mon mauvais français.
Dec 04, 2010 | Samsung Computers & Internet
CHAUFFAGE HABITACLE AUDI A4 1995 EN PANNE Où se trouve le thermostat ainsi que la sonde du radiateur ? il est à noter que le thermostat affiche une montée de température mais elle...
Tu devrais changer le thermostat du moteur, parce que la temperature reste a 60°C en lieu de 90°C quelle est la valeur normalle, et donc pas de chauffage habitacle. Le thermostat se trouve au dessous du pompe a l'eau pour le moteur 1,8 Turbo du Audi A4 1995:
Oct 16, 2010 | Audi A4 Cars & Trucks
My candy futura don't good work,it stop of work,sometime it is ok and afther it don't product cold,i don't know wich piece i must change(in french bilame or sonde) please help me(i don't speak anglish very...
Il s'agit soit d'une minuterie de dégivrage ou de fin de course, C'est le petit coup sur le dispositif situé sur le toit d'un de vos bobines congélateur. Ceci est l'élément le plus commun à mourir sur bon nombre des nouveaux réfrigérateurs. Il est également assez peu coûteux et facile d'obtenir de Sears ou de parties 1stsource. Dans de rares cas de dégivrage de votre chauffe-mai vont mal, mais je n'ai pas eu à remplacer l'un dans un long moment.
Mar 10, 2010 | Refrigerators
Fuite d'eau réfrigérateur samsung cooltech dynamic
Fuite d'eau du réfrigérateur ou dans le congélateur ou SECTION DES ALIMENTS FRAIS
Vous avez un blocage de votre ligne de dégivrage de condensat ou le tuyau qui remplissent le tiroir en dessous du réfrigérateur est absente du collecteur condensat qui utilise la chaleur dégagée par le ventilateur à l'arrière de condensat s'évaporent dans l'air intérieur de votre maison. Ou vous vous reconnaissez avoir un blocage dans le tuyau de drainage, enlevez le panneau arrière du congélateur ... vous mai voir l'accumulation de glace, faire fondre la glace avec un sèche-cheveux, vous verrez ci-dessous l'évaporateur une casserole, faire fondre la glace dans la casserole, l'eau sèche place dans une casserole avec une serviette, vous devriez voir trou de drainage dans le moule, qui conduit à la fuite des tubes, verser un peu d'eau chaude dans le moule, attendez quelques minutes, essuyer l'eau et répétez cette étape 2-3 fois, une fois que vous avez fait cette utilisation une voie humide et sèche sous vide aspirateur pour les saletés ou de blocage dans la conduite de vidange. Maintenant, il est nettoyé! Remettez le panneau arrière et que vous êtes prêt à continuer. La raison que vous voyez de l'eau dans le congélateur parce que l'eau a été une fuite dans le congélateur au lieu de courir dans le trou de vidange ... Si vous avez besoin d'aide supplémentaire s'il vous plaît n'hésitez pas à commenter à nouveau. Bonne chance! PS S'il vous plaît n'oubliez pas de noter mes Merci solution! Sea Breeze
Mar 01, 2010 | Samsung Refrigerators
Dometic RM2852 Refrigerator Logo
19 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
