Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My tv turns on for a few seconds then shuts off and then turns on and then shuts off and stays off....what is the problem and how do i fix it
  • RCA Master
  • 5,138 Answers
Look for Bad Capacitors on the Deflection Board,Bad caps will be vented,swollen or puffed up on Top. CP150 2200uf 16v use 25v
CP114 CP120 are 220uf 35v replace all 3 if CP150 is Bad.
Deflection Board is the bottom board on Left hand side,will have FBT flyback Transfomer on it.
Posted on Oct 07, 2010
  • 1 more comment
  • KjellElec Jan 21, 2011
    My Samsung does the same, grey light comes on only. It is an automatic update function, settable in the DTV menu system, not the normal menu.
  • ladywinn
    ladywinn Jan 21, 2011
    This is for the person with the samsung,you need to post your Model number that is printed on back of TV and what is the problem you are having .Thank You.
  • KjellElec Jan 22, 2011
    Answer to 2. ladywinn: I need to do nothing. Model number is uninteresting since the update functionality will be built into all TVs with DTV function. Also other brands will expectedly have this functionality. My problem was the headlined theme about turning on, then off, Of Course.
No.emerson tv.turn it on it shuts off.takes about 5x's to stay on
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox I demonstrate in this video how to repair a Sanyo by swap out the Analog power board on a 42 inch. This IC chip ...
Sep 27, 2015 | Televison & Video
Samsung UN46ES6500FXZA turns off by itself
I can not acces my Facebook deos not recognize or mail or password,how I can restart t.v to install and to atarte again please help me , thank you
Feb 10, 2014 | Samsung UN46ES6500 - 46" 3D LED-backlit...
Wont stay on when cold
This sounds like a power regulator issue. Check the site www.TvRepairKits.com for a "shrinking and expanding" video kit for your model. It also fixes the random off/on when the tv is cold
Mar 06, 2013 | Philips Televison & Video
My TV has been having a shacky picture when it first turns on for a few minutes, then clears up. the other day after using the TV for most of the day, it shut off unexpectidly, and now it will turn on and...
1. YOUR flyback is going bad 2. Peform a removal and replacement 3. check your error codes first to ensue nothing else exists 4. Proceed to change out the required parts 5. Observe all electrical risks 6. Order replacements from jimmyparts.com 7. Ensure to always remove power 8. Ensure to always use electrostatic wrist strap
Jan 31, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Hard to get tv to stay on. comes on then shuts right off??
I have a very similar problem with my same tv. I know you posted this a while ago but if u solved your problem I would love to know how to fix it, mine just went out with that same problem. And vice versa if I get mine fixed.
May 15, 2010 | Toshiba 65H84 65" Rear Projection HDTV
JVC model LT-37xm57 will not stay on
I believe it is an overheating problem...
Short term fix...place a small fan behind your TV on bottom right hand corner and your TV will not shut down
Mar 24, 2009 | Televison & Video
TV wont stay on
The vcr carriage was probably damaged ( broken gear or carriage gear, etc ), As for repairing it, it may not be worth it and chances are, you won't find a new carriage for the unit. I have, in the past, disarmed the VCR unit and at least the customer could watch the TV. Thats not possible in every set, but it seems to work in the majority of them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 22, 2007 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Turning on
These sets are notorious to have bad components in the power supply, and if you have solid state repair experience, you will need a service manual to repair this SMPS(switch mode power supply) Good Luck
Apr 29, 2007 | Philips Magnavox TS3260C 32" TV
Tv keeps turning off
If it's staying on for just a short period of time it sounds like there is a sensor that is giving the unit a faulty condition (Perhaps for reason or due to a fault in the sensor). There are normally a few temp sensors in the TV around the Lamp and Ballast. They may be bad, or the lamp or ballast is just generating too much heat.
Feb 05, 2007 | Panasonic PT-45LC12 45" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
