Question about Cobra 29 LTD CB Radio
When i hook up my cobra 29 Ltd to my pickup it keeps blowing fuses, red to postive and black to negative..Cannot figure out whats wrong
    Guru:
  • 773 Answers
You have hooked your power wire up backwards at some point and blown the polarity protection diodes.
This requires opening the radio and using a soldering iron to remove and replace the blown diode.
You will need:
  1. Soldering Iron
  2. Solder
  3. De-soldering braid
  4. N1004 diode or better.
  5. Phillips head screw driver.
Using the phillips head screw driver to take the bottom cover of the radio off being careful of the speaker wires. Using the soldering iron, heat the solder on the tabs of the speaker and pull off the wires. No need to use the de-soldering braid to remove the solder. You should do this to make it easier to handle the radio, and to avoid damage to the speaker or wires etc.
Now take the cover off the top of the radio. This will reveal the "Trace" side of the board. This is where all of the components are soldered to the board.
Now flip it to the other side where you can see all of the components and wires etc. Look at the back right of the radio by where the power socket is. Look for D23. its a big black diode. It will most likely be black and burnt. Some times it may not be.
Here is the tricky part. You need to locate the points at which this component marked D23 is soldered to the trace side of the board. Some times you can use a bright light and look at the trace side of the board while the light shines on the other side to locate the part.
Once you have located the points at which the diode is soldered too, do not de-solder it yet. Make note of which side of the diode the white band is on. This is important, putting the diode in with the wrong polarity will make the radio not work.
After you take note of the white band you may now use the de-soldering braid to remove the solder from the trace side of the board. To do this, place the braid over the solder point. put the tip of the soldering iron on the braid and press it down to the solder point. You will see it **** the solder into the braid.
Once the solder is off both solder point, flip the radio and remove the bad diode.
Put the new diode in, making sure the white band is on the same side as the original diode.
Once again flip the radio over to trace side of the board and solder the new diode in. To do this place the tip on the solder point, making sure to touch both the solder point of the board and the wire from the diode. take the solder and touch it to the solder point, not the soldering iron tip. Once enough solder is on the point you can remove the soldering tip. Don't use too much solder.
Once both points have been re-soldered, solder the speaker wires back to the speaker. Red is positive, it connects to the tab marked by the positive symbol "+". The white wire is negative. It goes to the negative symbol, "-". You can just reheat the tab, and put the end of the wire into the melted solder and remove the solder tip while holding the wire in place until it cools enough harden again.
After the speaker is re-soldered, Put the covers back on. Now be very careful hooking up the radio to power. If you hook it up backwards again it will blow the diode again. Once the power wire is connected, turn on the radio, it should work fine at this point.
Good Luck!
Posted on Oct 07, 2010
How do i find and replace the finals in a cobra 29ltd classic
The protection diode (a black, tub looking devise) hooked to the positive power wire near the back of the radio, is most likely your problem. Check to see if any doides are shorted by using a Volt/Ohm Meter by checking for a short. For more imformation or help, email me at wyoed1@aol.com.
"Original Radio Man"
Ed
Jan 01, 2013 | Cobra 29 LTD CB Radio
What would cause my cobra 29 to blow fuses when u turn on the power
You have a bad diode near back. Probably the black fat one with a stripe. Its located near power leads and audio transformer in one corner. Change all Black Diodes with (White) stripes in back. You must of crosswired it blowing the diode.
Mar 31, 2011 | Cobra 29 LTD CB Radio
Main power was hooked up backwards, now unit won't power up. how much damage is likely?
i gus i hook up the power up and blow some thing it is a black 29 cobra got aney thing to fix it
Feb 06, 2011 | Cobra 29 LTD CB Radio
When i hook up my cobra29 LTd to my pickup it keeps blowing fuses. What do i need to do or whats wrong.
HI, my name is John. Red to hot fuse under dash or battery and black to ground hope this was helpful.... good luck John
Oct 08, 2010 | Cobra 29 LTD CB Radio
29 LTD CB Radio: whats the color to number wiring for cobra mic...
This is for a cobra CA50 mic
1-sheild
2-white
3-red
4-black
May 07, 2010 | Cobra 29 LTD CB Radio
Have cobra 29 nw ltd keeps blowing fuses inline and in cigarette lighter adapter adapter is 10 amps and inline is no more than 5 amps
This is an easy fix if you are comfortable soldering.
You must have hooked it up backwards. Big problem when using a cigarette lighter adapter. You have to be careful, if you hook a radio up backwards you blow the polarity protection diode.
  • Go to radio shack and buy an N1004 diode.
  • Open the radio
  • Look towards the back right of the radio for a black diode D23. it will probably look burnt, but not always.
  • Use a soldering wick to remove the solder holding the diode in.
  • Remove it, and replace the diode making sure its going in the same direction as the old on. Strip on the side the triangle is pointing.
  • Solder it in.
  • Test the radio
That should do it.
Make sure you are careful to hook the radio up to power corrctly.
Nov 14, 2009 | Cobra 29 LTD CB Radio
Cb was hooked up backwords +-/-+ can it be fixed
Some of the car electronics will put crowbar DIODE in the unit, the Cathode will be connected to the incoming positive, and the ANODE will be hooked up to the Neagative, the DIODE will not conduct because ti will be reverse bias, so when the positve and negative is hooked up wrong to the unit, the Diode will conduct (forward bias) with a lot of current and blow the fuse that is inline with the unit, you should be able to connect the Ohm meter to the positive wire and the negative wire of the CB (remove it from the car first), if it indicate anything lees than 100 Ohms, the protection DIODE is shorted out and protected your CB, you just need to locate that Diode.
Nov 01, 2009 | Cobra 29 LTD CB Radio
Blowing fuses with wiring CB to battery
Is the wire going to the battery touching chasis ground at all? Accidentally pinched it, cut wire etc? If not the the power supply may be fried.
Jun 04, 2009 | Cobra 29 LTD CB Radio
Which wire is live on cobra 19x
the solid red wire is the battery plus or the hot wire. the red and black is earth or ground wire if the radio has been hooked up backward it may have blown the protection diode.
May 09, 2009 | Cobra 29 LTD CB Radio
Connecting a Cobra 29LTD to a Pyramid PS-3KX 13.8VDC Power Supply
The wires should just attach to the red and black terminals on the radio, strip some wire unscrew the terminals a little wrap behind, and tighten again. Good luck! Or buy some banana plugs and they will plug right in the front
Dec 18, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
140 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
