Question about Goodman GMS90703BXA Heater
Induction motor does not start - Goodman GMS90703BXA Heater
    Problem Solver:
  • 16 Answers
Ck for power to motor (120v). If u have power, it's the motor. If not, the connection may be loose at the computer board. if not, and ur sure you have power to the board, the board is board.
Posted on Oct 07, 2010
  • Goodman Master
  • 43,501 Answers
Check for power at the motor and if you have power the motor is bad.... if no power there then the relay went on the control module...you will need to replace the control.
heatman101
My rheem gas furnace got red button that keeps griping what can I do.
The red button that keeps tripping is probably the rollout sensor just above the burner assembly. When this rollout starts tripping, it means your flue gasses are not being drawn out by the induction fan motor. If your furnace is a few years old, the fan blade has probably rusted out and is not moving the flue gas. You will need to get a new induction fan motor. While you are checking the induction fan motor, it is a good idea with everything torn apart to check the condition of your heat exchanger. When the induction fan blade rusts out, it is a good indicator the heat exchanger may need replacing also. So do yourself and favor and check it out for rusted out welds and the like. You will probably need an experienced hvac tech to make the furnace repair.
Hope this helps.
Dec 31, 2014 | Heating & Cooling
Dryer wont start turning, I can turn the drum and it will start
It sounds like the device that starts the motor has died. Now you have to find out if you have a capacitor start motor, or one of the induction start types. If it's induction type, the motor will need to be replaced. If it has the capacitive starter, you may only need to replace the capacitor. This type has a large cylindrical cap, located in in a can that resembles a black quonset hut. Some small electrical repair shops will test your motor, if you bring it in, for a minimal charge, or possibly gratis.
Oct 13, 2014 | Hotpoint Dryers
Lennox g26q3
electronic ignition or pilot type? assuming electronic ignition, check the airflow sensor for dirt in the peto tube, or a defective sensor, if you hear the high voltage click but have a failed ignition chec that the pilot is being lit, and that the thermopile/infrared sensor is good. one of those is your problem.
Mar 23, 2014 | Heating & Cooling
Dewalt DW718 Sparks When cutting . just bought it
The people from Lowes were right.
There are two types of motor designs: Induction motors and brush-type motors.
All electric motors that have brushes make sparks where the brushes contact the rotating commutator. They also run less efficiently but they are a bit smaller than induction motors for equal power output. Brushed motors can also deliver greater power at initial startup.
Because the sparks in brushed motors create heat, the housing around the motors typically have ventilation slots for air to go through to keep the commutator cool. This means you are likely to see the sparks if you look in the right place.
Since it's more difficult to get an induction motor turning, they typically have a "start capacitor" mounted on the side of the motor to give an extra kick to get the stator turning. While induction motors use less power when running, the amperage they use at start-up is typically double the running amperage.
Sep 09, 2013 | Dewalt 12" Beveling Sliding Compound Miter...
My heil n9mp2 isnt working just hums
is the flame igniting and then cutting off? on a gas furnace, the induction fan motor(draft motor) should start first (if the furnace is so equipped), then the flame, then the blower. if you have an induction motor (flue gas exhaust mmotor) this may be your problem (the induction motor isn't starting), if your unit doesn't have one, have you checked to see that you have gas? finally, the capacitor on the blower motor may be causing the motor not to start.
Jan 06, 2013 | Heating & Cooling
Fan stopped working on our Bosch rangehood (Type D-FX41-8 or E-Nr. DKE935AAU). Lights working but the fan only inhibits a humming sound.
hi ;
the fan motor needs repair , the cause of humming is the vibration of induction on AC current in the motor.
if the motor stopped means it has faulty shafting and bushing, or maybe the starting capacitor needs a replacement, don't turn it on or use it to prevent burning of induction wire,
also it needs a qualified technician to repair ,
Sep 03, 2011 | Kitchen Ranges
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
Motor was working fine. Turn off to disconnect vaccuum. Turned back on motor just hums. Won't turn impellor. This is a 120vac single speed motor. It is only 1.5 years old. Is there something called a...
The type of motor that uses a centrifugal switch, a brushless induction motor is considered too large and heavy for a portable vacuum cleaner though they are often found in permanent installations.
Portable vacuum cleaners use a series wound motor that is considerably smaller and lighter for a given power output and turns many times faster.
Both types of motor will hum if seized or locked and in that condition the series wound motor will soon destroy itself. It takes a little longer for the induction motor to overheat...
The centrifugal switch is not fitted to all induction motors and that is usually very reliable and rarely gives trouble except when unused for a long time in damp conditions.
Many single phase induction motors with or without the switch use a starting capacitor and sometimes a start/run capacitor. Often the capacitor is of inferior quality and will fail with the result the motor will just hum, though will start when the shaft is spun by hand.
Feb 04, 2018 | AO Smith 1 hp 3450rpm 48Y Frame 230/460...
My heater won;t work
check induction fan motor first...then check the rubber tube and the switch it ataches too. this switch should close if the induction motor is running...but also...it HAS to be open before start up.
Dec 08, 2008 | Carrier 38CKC036 Air Conditioner
Goodman GMS90703BXA Heater Logo
324 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
