Question about World Marketing of America DH2304 DuraHeat 23,000 Btu Kerosene Heater - Refurbished
I need help with my dura kero heater. It won't light. Where do I put match at. What are the c batteries for. I turn the knob for the wick every way possible
Batteries are used to light the wick
Posted on Dec 14, 2010
Kerosene heater toyostove rca36has wix full of kerosene and will not light
trim the carbon edge off the wick
wicks work by being saturated in kero and then burning off the kero and not the wick
what you have is a carbon block on the end of the wick that is preventing the kero ignition
Jan 30, 2018 | Heating & Cooling
I have a small propane reddy heater with an electric ignitor if power is out can i manually light it
Yes, you can. Use either a butane grill lighter or a long stick match. Make sure the control knob is in the "light" position and the wick is in the right position. Light the long stick match or butane grill lighter, press the control knob in and while holding it in, touch the flame of the match or butane grill lighter to the wick and the wick should ignite. Once it ignites, quickly remove the match without knocking the tip off into the heater.
Jan 31, 2011 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Hi, I need a users manual for a Robeson Kerosene space heater model # 03-2619-91. I tried to light it with an open flame and nothing is happening. Thanks
DO not try to light with flame. Check fuel an vac lines first.then ck glow plug. to ck plug, remove leave power connected.to plug. ground plug to unit. Turn on switch.plug should glow bright red.
Jan 01, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Need a wick and battery pack for a TOYOSTOVE KSA-105, where can i find these?
Hardware stores usually carry wicks. One brand is Kero World. Wick #503K works for the KSA-105. I have one that I bought and the person never brought their heater by so I could replace the wick. The battery pack could be ordered through a Toyostove dealer.
Oct 07, 2010 | Rinnai Toyostove Direct Vent Heater:...
Is it possible to manually ignite a corona 22dk kerosene heater safely with a butane lighter? the battery operated igniter is not working with new batteries installed.
I just use a match. Turn the setting dial to High. Open the little door in front. The one with glass in it. Light the match. Push the pedal down that you normally use to start it with the battery starter. Put the match into the heater and touch it to the wick. With just a regular match, I can reach in far enough to light the wick. When you have a complete ring of fire, lower the pedal slowly and close the door. It will smoke briefly and then burn. After 15 minutes lower the wick till the flame is smaller and whiter.
Sep 13, 2010 | Corona 23-DK Compact Heater
RMC-95C6 wick replacement
REPLACEMENT WICK NUMBER: Kero-World 32225, Dura Heat DH-145, Glowick 30856.
Sep 07, 2009 | Dyna-Glo RMC-8001SS Heater
Corona DK 23 kerosene heater won't start
try bringing your wick up to the fully raised position and pinch and bend the wick toward the igniter until they line up right. I have two coronas one of which has a broken igniter due to wear and tear. If you open the little door,press down the start lever,and light the wick with a barbecue grill lighter,you can safely light the heater if lining up the wick fails.
Oct 09, 2008 | Corona 23-DK Compact Heater
Dyna glo RMC95C6 kero heater
I suggest you replace the wick and clean the wick feeder assembly. I did not own that model but did have one a number of years ago. The wicks can begin to dry out.
Jan 08, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Electric starter
I have a different make and model, but many of these use a similar design. A battery pack (2 x D or C cell) is mounted on the kerosine tank. The batteries are used to heat a coil. The coil is pressed by an external button against the heater wick. Pressing the button also engages the switch, heating the coil until it glows red hot.
1. Open the burner chamber of the unit and confirm it has a wick installed (this is a used heater--who knows it's condition). Close the chamber.
2. Make sure the tip-over protection hasn't retracted the wick. Generally the tip-over protection is reset by a lever on the base of the burner.
3. Adjust the wick all the way up. A knob on the base of the burner does this.
4. Fully depress the electric starter until the coil touches the wick.
5. When the kerosine on the wick ignites, release the starter and adjust the wick to the desired level.
If the electric start coil does not glow, check the batteries. If the batteries are good, the starter coil may be bad. These are also
replaceable.
Nov 08, 2007 | Corona 23-DK Compact Heater
Heating & Cooling Logo
178 people viewed this question
Top World Marketing of America Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a World Marketing of America Heating and Cooling Expert? Answer questions, earn points and help others
