Good Afternoon Guru, Re your post By sthomas556 on Oct 05, 2010 I have a Smart Drive Fisher & Paykel 7.5 washing Machine and my darks come out of the wash with hard to remove fluff I have a Fisher & Paykel Smartdrive 601 - Model No. GW601-U S/N MAL58247. I followed your instructions and got so far as trying to remove the tub. It won't come out, gets stuck on the motor pulley and rod. It moves a little bit and then won't budge pass the cog. Is there any tricks her, maybe a special tool or do I have to undo some bolts from the bottom (sort of reluctant to do that), a friend at work mentioned it was magnetic? I have a broken finger and it was an effort for me just to try and remove the tub lol. My problem is the same it leaves lint and powder on my dark clothes and guy cleaned it for me over 5 years ago (but alas I didn't watch what he did) Any help ideas would be most appreciated. From trying to be a handy woman - with a broken finger lol
  • fiona_duncan Oct 07, 2010
    Hey thanks for that, I still have it dismantled so is there a trick to my original request, getting the tub out?
    I have a top loader and there is no flint removal in this machine, does that still apply to your advice above, just noticed you mentioned front loader.
    Thank you
    Trying to be a handy woman
  • 11,896 Answers
Possible a lint filter problem, but first I would take off the pump and clean it out along with the drain hoses and see if that does not fix things.
First check your washer for a lint catcher.
Mine is in the center on the agitator,mine takes one twist to remove.
wipe out washer after washing towels and rags etc.. to remove excess lint.
Posted on Oct 07, 2010
    President:
  • 1,891 Answers
I don't think we talked before . but before disamble ( I would use a cleaner like washermajic. this works well in front loaders. . cleaners reduce the deposits and clean right to the metal . they do not harm the inter or ss metal. safe for seals . also white deposits are either hard water or soap . . if your using a H E detergent . you should not get the build up ./ some reg detg.just do not work well in front loaders.. also ck the drain hose it may be in the stand pipe so far its end is in the elbow . this will cause siphon back to the tub .. hope some of this helps mm
Fisher and paykel smart drive 5.5 won't start a wash cycle, no lights flashing or beeping looks normal but won't start
Contact Fisher and Paykel Service Center and DO NOT TRY TO OPERATE THIS MACHINE UNTIL CHECKED & VERIFIED BY AUTHORIZED FISHER AND PAYKEL SERVICE PROFESSIONAL.
Apr 28, 2014 | Washing Machines
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel smart drive 608 6.5 kgs has running well for ages but recently while finishing water filling it makes a warning beep sound and start leaking from the bottom,anyone there to help me pls
Hi just read your post.Now when the machine beeps a series of lights will light up on the wash progress lights. The spin light is number 8 and the other end of the lights is number 1 which is long wash, i think. Starting from the long wash light which is number 1, which lights are on when the machine is beeping, is it 1,4 and 7 or 3, 7 and 8 etc? Please reply with the answer to this question and i am sure i can help you. Regards Lu
Jan 25, 2014 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel smart drive 601
Hi just read your post.When the machine beeps a series of lights will light up on the wash progress line of lights. Staring from left to right the long wah is number 1 and the spin light is number 8 which lights sre on when the machine beeps, is it 2, 4 and 8 or 1, 3 and 7 etc.Please reply with this information and I sure I can help you. Regards LU
Jan 24, 2014 | Fisher and Paykel Fisher & Paykel Washer
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
FISHER & Paykel 6.5 Smart Drive - No display lights
You need to get hold of a multi-meterand check the resistance of the pump, It should be 33ohms or close to it, the pump is part of the power circuit and the machine will appear dead if it has blown or is unplugged, If the machine was running without the earth wire to the pump connected and the pump had a fault/blockage there is a very good chance that it has blown the motor controller module. It requires the earth to provide a fault path to earth.
Mar 03, 2012 | Fisher Paykel Eco IWL16
After replacing a hot water hose on my Fisher & Paykel Smart Drive 603, the machine now needs to be rre-set I think. Where would I find that button please??
Hi just read your posting.Why do you think the machine needs to be reset?Is the machine working?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
May 20, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
