Question about Gigabyte 7VT600P-RZ (GA7VT600PRZ) Motherboard
Can't install sata hdd. When copying driver files to floppy from oem disk, keep getting "txtsetup.exe not found
3 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Sata hd, installing windows
Hi nveronika,
First things first. Find the name of you're SATA hard disk drive.
Please go to the manufacture's web site & download the floppy drive setup/utilities bootable software or creat a bootable CD from the manufactures site. Boot the system with their software & setup you're hard disk drive which will run in a DOS like window. (This should resovle the blue screen issue).
There are two different revision for the motherboard GA-M52l-S3
(Revisions, 2.0 uses the NVIDIA® GeForce 6100 / nForce 430 chipset): http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2818
& (Revision 1.0 which uses the NVIDIA® nForce 520LE Chipset): http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2634
Which is you're motherboard? Once you find the correct motherboard you can download the the needed software directly from the web site & create the correct floppy disk needed when pressing the F6 key during windows installation. If you still get an error message try another fresh floppy disk. (Corruption of files to a floppy usually mean the floppy drive is dirty or bad or the floppy disk is bad). It is also possible that the data cable to the floppy drive is loose or defective. Downloading directly from Gigabyte is suggested over using the CD.
Good luck nveronika!
Mike
Posted on Aug 30, 2008
SOURCE: Can't install Hard Drive MS Server 2003
HI.. please specify the ASRock motherboard model, check whether it is using which chipset as SATA Controller... ICH6 or ICH7 or ICH8 or ICH9
ICH5/6 Sata Raid drivers
http://down3.driversdown.com/Bios/ich5r_6300esb_ich6r_msft_raid.exe
ICH6/7/8 Sata Raid drivers
http://down3.driversdown.com/Mainboard/iata621_cd.exe
ICH9
http://downloadmirror.intel.com/14849/eng/f6flpy32.zip
Please tell me if u need anything else.....
Regards,
Siddesh Prabhu
Posted on Sep 28, 2008
WATS THE PROCEDURE OF INSTALLED SATA DRIVER ON P5RD1-VM?
put the one end SATA cable to the HD and other end to motherboard then connect the sata power cable to the hd as well.
Sep 15, 2009 | ASUS P5RD1-VM Motherboard
Trying to install wd 160gb sata drive on xp home sp2
i think instead of enabling sata y dont u try enabling IDe
Nov 24, 2008 | Mach Speed (PM9MS) Motherboard
Need a disk to set up my maxtor drive
The disk that u need is maybe provide by your motherboard vendor. It's in your motherboard driver & device cd provided when u purchase the pc. Try to search the "sataraid or satarid floppy" in the cd. Then copy it into a 3.5 floppy disk. Remember, the files or folder that u will need to copy must have the txtsetup.oem file.
Sep 20, 2008 | Computers & Internet
Hi nveronika,
Mike
Aug 30, 2008 | Intel Motherboard
ICH9
Regards,
Siddesh Prabhu
Sata hdd cant install
hi
go to your bios setup
go to advanced option your sata hdd is disable enable it.
if it is enable then boot your sys with bootable disk
go to dos mode.
type FDISK
Y
4 TO DISPLAY INFO OYUR PARTITION.
IF YOUR PARTITION ARE NON DOSE DELETE IT
THEN RESTART YOUR SYS.
U CAN INSTALL XP NOW.
Mar 25, 2008 | Mercury KVM800M Motherboard
Computer system problem
Your hard disk might be SATA interface, and XP don't have access to this type of hardisk. It requires RAD driver for that type of disk.
1). You can make your HDD accessable to XP by disabling the SATA mode in your system BIOS setup. Then XP will access your HDD and it will be installed.
2). You can also make your HDD accessable to XP by atchi driver. Go to your motherboard manufacturer site and download SATA driver according to model number. This may be compressed or auto extract exe. Extract all files and copy it into a floppy disk. Then start your XP and press F6 at first screen, then it will be prompted to insert RAD driver from setup, follow the instructions and XP will be installed on your system.
Thanks
Iqbal
Mar 18, 2008 | Computers & Internet
try running scandisk on the floppy disc to fix errors with the txtsetup.oem file.
Aug 16, 2007 | Asrock K8 Combo-Z Motherboard
No HDD Found on initial XP Install
Did you insert the sata driver disks when prompted in the first stages of installation? I think it's mentioned as scsi drivers.
Mar 04, 2007 | Mach Speed (S755) Motherboard
Open Questions:
Gigabyte 7VT600P-RZ (GA7VT600PRZ) Motherboard Logo
97 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
