CPU will start and after 1 minute it will automatically shut down? What is the problem of my CPU.
  • 32,281 Answers
The problem most likely a thermal overload, the CPU shuts down when it over heats and will not boot up again until it has cooled down. If this problem is not fixed the the CPU will eventually fail. This problem is usually caused by a faulty CPU fan.
Replace the faulty fan and remove the dust from the heat sink
Posted on Oct 07, 2010
Cpu shuts down automatically after running for a few minutes
open the cpu cover. check your cpu fan on the processor weather it is running. and check the heat sink is tightly fixed on.
Nov 25, 2013 | Asrock K10N78M Motherboard
Does the 2000 dodge stratus has an automatic shut down relay that triggers when the oil pressure is to low?
The CPU has read low oil pressure and has shut down the system to protect the engine which it has done. However it cannot tell when you add oil so to get it to change you will have to reset the CPU.. Possible removing the battery lead for 5-10 minutes will reset or have a code reader instrument reset it.
Apr 27, 2013 | 2000 Dodge Stratus
Laptop shutting off every few minutes
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 03, 2013 | Lenovo 3000 N100 Notebook PC
I have ( IBM ThinkCentre 80847eg ) after starting power it shutdown automaticly after 30 seconds so i push power button again ,then it takes 3 minutes to get windows logo . so what's the problem
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 29, 2012 | Computers & Internet
My laptop turns itself of after 3 - 5 minute
Check the charger of your laptop if there is any place that has problem or cut? check the voltage of your laptop whether is the same thing with the charger. If everything are fine, then reload your operating system, because I have noticed this problem with my clients. Good luck
Feb 03, 2011 | Dell Latitude D600 Notebook
PC keeps shutting down and then re-boots automatically about every 20 minutes .
Shut it down.
Remove the power-cord.
Buy a can of compressed air ($3 to $5).
Remove the side panel(s).
Hold the can of air vertically (do not tilt it),
and blow away the dust from everywhere: inside the power-supply,
between the "blades" on the heat-sink & fan on top of the CPU.
Replace the side panels.
Reconnect the power.
Start it up.
Click Start
Right-mouse click on My Computer
Choose Properties
Choose Advanced.
Under "Startup and Recovery", click "Settings".
Click to disable "Reboot Automatically".
The next time that it crashes, what error-messages _stay_ on the screen?
Oct 10, 2009 | Microsoft Windows XP Professional for PC
Power problem in intel d865gvhz
Pull cmos cell from motherbord for 10 minutes.
So all motherbord settings defaults.
Then reconnect ATX power supply connector from smps to motherbord.
If still face same issue then you need to change or repair your SMPS.it is in back top side of cpu cabinet.
Try with other smps if still same issue then your motherbord has some issue.
You can trouble shoot this issue with above step follow 1 by 1 .
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Intel D865GVHZ Motherboard
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
Dell gx270 {switch}
My motherboard shows error thermal error and after 3 minut its power is close automatically
Apr 10, 2008 | Dell (4T274-DE) Motherboard
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
